Author Topic: BSIDE ESR02 Pro Transistor Tester (teardown & quick test)  (Read 46365 times)
Offline tppc
Re: BSIDE ESR02 Pro Transistor Tester (teardown & quick test)
« Reply #50 on: October 09, 2020, 07:32:17 pm »
Hi there,
Firmwares for BSIDE ESR02 Pro and other TT https://yadi.sk/d/yW8xa5NJgUo5z
thanks for the link, however, I could not figure out how to download the archive.
edit : OK I finally got the hex file, will try to flash it later.
Regards
« Last Edit: October 09, 2020, 07:53:57 pm by tppc »
Offline Lucky-Luka
« Reply #51 on: June 09, 2022, 01:45:38 pm »
Can this tester test triacs?
Memento audere semper.
Online Grandchuck
« Reply #52 on: June 09, 2022, 02:16:39 pm »
Yup
Offline Lucky-Luka
« Reply #53 on: June 09, 2022, 03:40:30 pm »
Do you think it's one of the best in this price range (<100E)?
p.s. does it even test thyristors?
Online Grandchuck
« Reply #54 on: June 09, 2022, 04:01:25 pm »
It tests low power unidirectional and bidirectional thyristors.
I have no way to judge if it is best or not.  To me, it is a good value.
Offline Lucky-Luka
« Reply #55 on: June 09, 2022, 04:04:51 pm »
I see.
Sounds promising.
Does it come with some more features compared to LCR-T7?
Online Grandchuck
« Reply #56 on: June 09, 2022, 04:45:19 pm »
The LCR-T7 has an IR detector, thus giving it an advantage if you need that capability.  Otherwise, they are similar.
I have never used an LCR-T7 so cannot compare actual usage.
Offline madires
  • A qualified hobbyist ;)
« Reply #57 on: June 09, 2022, 05:12:19 pm »
If you like to have the IR receiver/detector use the m-firmware. Then you can simply connect an IR receiver module to the probes and have fun with remote controls (supports about 15/20 protocols).
Offline Lucky-Luka
Offline madires
« Reply #59 on: June 11, 2022, 09:28:13 am »
Please see https://github.com/madires/Transistortester-Warehouse for documentation and firmwares.
The following users thanked this post: Lucky-Luka
Offline XerXes777
« Reply #60 on: December 08, 2022, 06:22:17 am »
Come from Germany. I would also like to buy the BSIDE ESR02 PRO. Do you have a recommendation where I should buy the device? If it is necessary I would also like to flash the device.  Have never flashed an AVR. What do I need for this? Are there more hardware versions of this device? Which I must consider when flashing?
Offline madires
« Reply #61 on: December 08, 2022, 11:27:08 am »
You'll need an AVR ISP programmer, e.g. a USBasp, and a PC (there are ton's of guides/videos on how to program an AVR). AFAIK, the BSIDE ESR02 PRO comes in two colors (red or black case) and you can get it at your preferred shopping platform.
The following users thanked this post: XerXes777
Offline XerXes777
« Reply #62 on: February 17, 2023, 04:15:25 pm »
I have received a BSIDE ESR02 PRO. With a different hardware version.
Which version can I flash there?
Where are the ports to flash? In the middle?
Which port is what?
Is there a ready compiled version for this board and which is also the latest?
Can I also measure a wire (eg coax cable) inductive or capacitive with this meter?
Offline madires
« Reply #63 on: February 17, 2023, 06:19:33 pm »
You can program k or m-firmware via ISP (J6, needs a simple adapter). For the pinout please see https://disk.yandex.ru/d/yW8xa5NJgUo5z/BSideESR02(DTU-1701)/Schematic%20diagram/DTU-1701_V3.1.JPG. AFAIK, there's no current ready-to-use k-firmware available, and m-firmware needs to be customized and compiled anyway. Low inductance values (<10µH) can be measured by k-firmware's SamplingADC.
« Last Edit: February 17, 2023, 08:02:06 pm by madires »
Offline XerXes777
« Reply #64 on: February 18, 2023, 04:43:38 pm »
I'm sorry, but I don't understand which firmware is from whom.
m-firmware -> Markus Frejek
k-firmware -> Karl-Heinz Kübbeler
m and k-firmware modified -> https://github.com/madires/Transistortester-Warehouse
Offline madires
« Reply #65 on: February 18, 2023, 07:07:50 pm »
Markus Frejek started the project originally but abandoned it after a while. The m-firmware is my crime scene. ;D And that github repo too.
The following users thanked this post: horo
Offline XerXes777
« Reply #66 on: February 18, 2023, 08:23:14 pm »
I read the documentation from https://github.com/madires/Transistortester-Warehouse/blob/master/Documentation/German/ctester-1.48m.pdf
Under point 7.3 i found the config for my test unit: BSide ESR02
So i can use these configs to setup the code and then i have to compile it?
And use the m-firmware?
sorry i read the threads, but i dont understand, what is the best firmware for this unit Bside ESR02.
Offline madires
« Reply #67 on: February 18, 2023, 09:43:57 pm »
Yep, those settings are needed to set up the m-firmware for your tester. You can also find them in the 'Clones' file. Simply try both firmwares (k and m) and keep the one which suits you best.
Offline rogerdammit
« Reply #68 on: March 15, 2024, 07:52:45 pm »
If it helps anyone, I just captured a quick guide to flashing the BSIDE: https://github.com/roger-/bside-firmware
The following users thanked this post: jax
