Author Topic: Keysight U1282U Temperature in Secondary Display in Degrees C Only?  (Read 1018 times)
Offline AJ3GTopic starter
All:
I have reviewed the manual, and spoken with an applications engineer at Keysight regarding the subject line. I just received a U1282A. The ambient temperature in the secondary display only reads Degrees C. My understanding is this is the ambient temperature collected from a sensor located inside the 1282A. The only time I am able to get the secondary display to read Degrees F, is when I turn the rotary switch to the TEMP position and press RANGE both the primary and secondary display Degrees F, but if I turn the rotary switch CW/CCW to another mode the secondary reverts back to Degrees C.
I have also gone into the menu and attempted to change the “Unit” from C - F to just Degrees F. No matter how long I press the SAVE button the change in this menu is not accepted, and I revert back to the default setting.
While reading the manual, I do see that changing parameters in the “Unit” menu may be restricted based on the country you live in.  This multimeter was shipped from a major United States Keysight Vendor, to the United  States, so I do not see how this restriction would apply to this Multimeter.
I am running Firmware Ver 1.05 which is the latest from Keysight. The application engineer I spoke to agreed this should not be happening, but wanted me to write my findings up so he could send it up to a higher tier of technical support. Before getting folks at the factory spun up on this write up, I wonder if anyone here can confirm what I am seeing?  If so, were you able to overcome this issue, and how?
Thanks in Advance!
« Last Edit: November 01, 2019, 03:27:51 am by AJ3G »
Re: Keysight U1282U Temperature in Secondary Display in Degrees C Only?
« Reply #1 on: November 09, 2019, 09:07:15 pm »
Just thought I would update - I have sent this issue to the product support team. Hopefully it can be resolved with a firmware upgrade, and I do not have a meter where this feature is disabled.
« Reply #2 on: November 06, 2020, 12:44:57 pm »
Just an update - Still no release of firmware which resolves this issue. I had reported it last November.   :--
Rich
