Author Topic: Teardown & Experiments with an Anritsu MS9710B 0.6-1.75um Optical Spectrum Anlzr  (Read 2649 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
You can watch it here: [26 Minutes]
youtu.be/dpCK6NXGqe0
More videos at The Signal Path:
www.TheSignalPath.com
The following users thanked this post: SeanB, thm_w, bjcuizon
Offline TiN
  • Country: ua
    • xDevs.com
Top notch, as usual.  :-+
Offline Dubbie
At first I thought “Not another spectrum analyser repair!” Then I saw it was optical. Nice! Very interesting.
What’s wrong with spectrum analyzer repairs? I thought people liked those.
Offline Dubbie
Nothing is wrong with them. I do like them. However there has been a lot and variation is the spice of life!
Offline _Wim_
To answer the question about the increased noise with the output attenuator turned on (if this is normal), mine (a MS9710C) does it also. However, my unit was pretty beaten up when I bought it, so it could just be a common fault from a weak part...
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
Nice! :-+
What type of optical connector is that?..the one on the front panels of most of your optical instruments.
Don't mess with an Electronics Engineer, it Megahertz!
Offline _Wim_
That would be the FC/PC-connector (non angled version). Sometimes it is also the FC/APC (angled version). The angled one are typically green (but not always).
The following users thanked this post: bjcuizon
Nice! :-+
_Wim_ provided the answer above. I also have a few videos about optics and I go through the details of these things.
The following users thanked this post: TiN, bjcuizon
Offline bjcuizon
Thanks for clarifying that to me.
« Last Edit: October 10, 2017, 12:02:21 am by bjcuizon »
