Author Topic: Real or fake: Keithley DMM6500 on AliExpress  (Read 3335 times)
Offline Zucca
  • EE meid in Itali
Re: Real or fake: Keithley DMM6500 on AliExpress
« Reply #25 on: February 07, 2025, 03:55:30 pm »
Definitely go for IPS if you can, DMM6500 uses a COTS display with early units being TN, later IPS, the later ones look much nicer.
How do I tell if my DMM7510
Five-inch capacitive touch, color thin-film-transistor (TFT) WVGA (800×480) with LED backlight.
 has TN or IPS?
ah:
https://newhavendisplay.com/blog/tn-vs-ips-whats-the-difference-/
https://www.lcd-module.com/lcd-tft-code-example-programming/better-ips-tft-tn-lcd.html
« Last Edit: February 07, 2025, 04:11:00 pm by Zucca »
Can't love what you don't
Offline Zucca
  • EE meid in Itali
« Reply #26 on: February 07, 2025, 04:13:31 pm »
Not the same LCD model but most likely should work just fine as it uses pretty standard LCD, worth a try for just $9. https://www.aliexpress.com/item/1005005199455421.html
I can confirm that IPS LCD from Aliexpress works fine in 34461A. Since it costs peanuts, I thought it wasn't a bad idea to upgrade TN display in my early 34461A. Good brightness, viewing angles, contrast.
you should report it in a new thread "TN display upgrade to IPS in TE"
Offline neverendingstudentTopic starter
    • YouTube Channel
« Reply #27 on: February 10, 2025, 02:57:18 pm »
Thank you for this confirmation that this specific part is compatible.  I've bought 2 of them so I can swap 1 and have a spare.  We'll see how it goes.
Offline hugos31
  • Country: pe
« Reply #28 on: March 17, 2025, 02:22:01 am »
I have problems... I updated the firmware. The battery is fine... what could it be? :palm:
