Author Topic: Two Questions about SDG1064X  (Read 241 times)
Offline watchmakerTopic starter
  • Self Study in EE
« on: March 17, 2025, 02:58:54 pm »
Two questions regarding the SDG1064X.
Is there a mechanism to ensure the generator is at factory default?
Second regards using the sweep function.  I am not successful in creating an "S" signal for aligning FM. (Developing a STEM program around this).
The Elenco instructions just say set the Sweep to 10.7 MHz.  I tried using Ch 2 for trigger output and also just triggering off Ch 1.  Played with sweep times and got a stable signal with 1Hz sweep.  BUt I really am not getting this.
I have no problems with FM Modulation at 10.7 MHz and can do the alignment with the kids that way; but I would like to understand how to get "S" curve.
THANKS!
« Last Edit: March 17, 2025, 03:00:25 pm by watchmaker »
Offline tautech
Re: Two Questions about SDG1062X
« Reply #1 on: March 17, 2025, 03:31:09 pm »
Getting the model correct might help with getting info.
SDG1062X
Main thread:
https://www.eevblog.com/forum/testgear/siglent-sdg1000x-waveform-generators/
Sure there is, 2 methods actually.
P80 2.13.1 System Settings
https://siglentna.com/wp-content/uploads/dlm_uploads/2024/08/SDG1000X_UserManual_UM0201X-E01H.pdf
Utility>System>PowerOn = Default or Last (used settings)
Default = All the settings return to default when power on.
Last = All the settings return to the setting of last power on.
OR
Utility>System>Default = Set all the settings to default.
« Last Edit: March 17, 2025, 03:32:40 pm by tautech »
The following users thanked this post: watchmaker
