Thank you. It is expensive but it is good tool. As i was thinking to get cheaper scope with built-in sig gen i was thinking that this could be cheaper. Around 50-100 €/$. This does not work?
The specs for this unit are shown below. It is for FM transceiver testing (or it could put out unmodulated RF (CW) ) . This is stated even more clearly in other product descriptions for it. So it doesn't do AM modulation. It also only has 800 Hz modulation for FM, and doesn't state the deviation the FM output is set to. You said earlier you wanted AM modulation too. So you tell us - is that what you really want?
Features:
Suitable for FM walkie-talkie debugging.
Built-in 800Hz audio modulation, with the analog digital CTCSS function.
The unit is DBM. General hand sensitivity is -120DBM to -130DBM.
The greater the sensitivity to a negative number, the higher the sensitivity.
The signal source cannot input power.
It is absolutely forbidden to press the intercom button to transmit when testing. (self-matching power supply 8V-12V power supply polarity is positive and negative)
Specifications:
Material: ABS
Color: blue
Frequency: 0.5MHz-470MHz
Signal strength: -70-132dBm
Add the analog digital CTCSS function
Use 8-12V DC power supply, frequency 7 digits
For example: 439.6000MHz shows 4396000KHz
Signal strength -70-132dBm valid, other values are invalid.
Audio modulation is only about 800Hz, other values are invalid.
Item size: 155 * 120 * 63mm / 6.1 * 4.7 * 2.5in
Item weight: 271g / 9.6ounce
Package size: 210 * 160 * 70mm / 8.3 * 6.3 * 2.8in
Package weight: 303g / 10.7ounce
