One of the features of the Tek 2465 DMS with the DMM option is the ability to measure temperature using the Tek P6602 Temperature probe. The probe utilizes a thermistor as it's measuring device. A quick search of the web for either the probe itself or a manual has resulted in what I think are ridiculously high prices for either the manual starting at $20 or the probe itself starting at $50. If it's just a thermistor why not build a clone? But the only info I can find on the thermistor is that it should be 100 ohms at 0 degrees C. And it doesn't specify if it's NTC or PTC. But thermistors are sold specifying their resistance at 25 degrees C. So....does someone have a manual or the probe and can tell me the thermistor value at 25 degrees C? That would also tell me if it's NTC or PTC. That would give a starting point to experiment.
Thanks.
