Apparently one of our techs at work fed his scope a little too much voltage. We test high voltage products here and he thinks he had a transient spike up to 6000V during a stability test. I doubt his front end saw near that much since we use a 1000:1 divider, but still it does seem to be busted.
It powers on and eventually just sits at a blue screen that tells me the model number and serial number and probably firmware revision. So to me it seems like it self tests and then stops when trying to communicate with what they call the "main board" in the service manual. I guess I was thinking I'd find something in the input stage and just replace it, but I don't have any experience with Tek's digital scopes.
What do you guys think? Is it worth bothering with? Or should I just toss it?
