Author Topic: Buying a scope for measuring RF waveforms  (Read 1111 times)
Offline Mike99Topic starter
« on: November 01, 2023, 10:37:14 am »
Dear experts
I'm a radio amateur and my main use for a scope is to measure AF and RF waveforms up to 50MHz. I rarely need to examine logic waveforms.
I currently have a venerable Tektronix 2340A which does the job but is big, heavy and noisy and I'd like to replace it with something new.
I'm only a couple of miles from a major UK supplier of test equipment, including Siglent, Rigol and Micsig scopes, and the Siglent SDS 1202X-E is looking attractive. I only need 2 channels and don't want to spend more than £400.
Not being a scope expert I'd like to hear your opinions on whether this will suit my requirements.
Thanks!
Mike
Offline tszaboo
Re: Buying a scope for measuring RF waveforms
« Reply #1 on: November 01, 2023, 10:48:27 am »
What's the reason you would want an oscilloscope for such a job, instead of a spectrum analyzer? That's usually not the right job for that task, even if it has FFT, the signal levels for a scope is much higher, the dynamic range is much lower, you don't have 50 Ohm termination on the low frequency scopes, the input capacitance is high and so on. I would guess even an SDR would be better, or a low cost spectrum analyzer.
Offline tggzzz
« Reply #2 on: November 01, 2023, 10:59:56 am »
Measure what, exactly?
  • frequency? A frequency counter will give more accurate results faster
  • amplitude? Scopes are only 2% vertical linearity, at best. To that add the effects of the scope's frequency response, the probing technique (especially resonance), scope VSWR (probably 1:1.3, i.e. >2dB) Better to use a power meter or spectrum analyser
  • power? See amplitude, especially for low powers
  • harmonics? Not a chance with a scope due to non-linearity and/or ADC resolution. A spectrum analyser is much more appropriate.
  • modulation? What type, e.g. amplitude, phase, frequency? FM/PM better with a modulation domain analyser which showing frequency vs time. Or an SDR
Summary: a scope is a time-domain instrument. RF measurements are usually frequency domain and lower power. Choose the right tool for the job.
Personally, if I had a working scope that does the job, I would spend my money on something that gave me new and different and interesting capabilities.
« Last Edit: November 01, 2023, 12:42:54 pm by tggzzz »
« Reply #3 on: November 01, 2023, 01:12:39 pm »
I already have an SDR with spectrum analyser software, frequency counter, modulation meter, RF millivoltmeter and a power meter. I'm interested in every day general measurements of peak-to-peak amplitude, noisy waveforms, 2-tone tests of SSB transmitter linearity etc. Nothing fancy.
Mike
« Last Edit: November 01, 2023, 01:14:14 pm by Mike99 »
Online nctnico
« Reply #4 on: November 01, 2023, 01:13:50 pm »
AFAIK the SDS1202 gives you the most bandwidth for your money.
Offline tszaboo
« Reply #5 on: November 01, 2023, 02:26:14 pm »
Mike
All these are typically measured on a spectrum analyzer. Try to borrow a TinySA or a used SA to see how it does it. Or the TinySA is like 70 EUR, hard to go wrong with that.
