Author Topic: Cables for my function generator?  (Read 3589 times)
Offline MusteyTopic starter
« on: May 08, 2020, 04:41:30 pm »
I bought me a Siglent SDG 1032X.
Pretty sure I don't need one :) But I am going to try and keep it relevant in my studies...
It arrived with a power and USB cables. I would like to have some cables for connecting to my projects.
1. I do have probes from my scope, but I have a feeling I am not supposed to use these as outputs from my gen?
2. Can I call gen output cables "leads"? (Not a native English speaker)
3. Any recommendations on which cables/leads to get? I am just starting to learn electronics and will be mostly inspecting basic components like caps, transistors, coils (to analyse stuff like high/low pass filters, modulation, etc...). I do want to do a little basic radio transmission (like one circuit talking to another circuit in the room) and micro-controllers (ATmega328, ESP32, etc...)
4. I've read that "it depends if you do high frequency stuff". In this context (studying filters, radio and controllers), what is considered "HF"?
Offline Grandchuck
Online RoGeorge
Re: Cables for my function generator?
« Reply #2 on: May 08, 2020, 05:54:56 pm »
You need to search for BNC 50\$\Omega\$ cables.  Example:
https://eu.mouser.com/Connectors/RF-Interconnects/RF-Cable-Assemblies/_/N-bsiqa?P=1z0x0emZ1yzsqvbZ1yzsqva
Be sure that are 50\$\Omega\$ and not 75\$\Omega\$.  There are also plenty of 75\$\Omega\$ BNC cables on the market, too, but those are for video equipment interconnections.  If the webpage doesn't specify the impedance, chances are those are video cables, I know because I bought a few of those, only to discover later they were 75\$\Omega\$ BNC to alligator cables.  At low frequency, the cable impedance may not matter much, but why not buying the proper 50\$\Omega\$ cables from the very beginning.
In an emergency you can use any other cables, too, including the oscilloscope's probes set on x1, but better keep the oscilloscopes probes for the oscilloscope.
Later edit:
Fun offtopic, the capital Omega letter is rendered differently when there is a space between the number and the symbol.
50 \$\Omega\$ vs 50\$\Omega\$  :)
« Last Edit: May 08, 2020, 06:43:44 pm by RoGeorge »
The following users thanked this post: duckduck, Mustey
Offline bob91343
« Reply #3 on: May 08, 2020, 06:39:57 pm »
I agree that some ordinary 50 Ohm cables are called for here.  One needs a stock of various lengths as well as terminations in BNC or test leads.  And yes, make sure you use RG-58/U for 50 Ohms.
These cables will serve for other purposes, such as connecting counters, analyzers, and such.  You will also be wise to obtain some adapters, such as female-to-female and to other connector series such as UHF, SMA, and N, and even T-adapters for connecting multiple instruments.  Further, one or two 50 Ohm feedthrough terminations will be useful.
Online MarkF
The following users thanked this post: tautech, petrinch
Offline tautech
Avid Rabid Hobbyist
Offline Gandalf_Sr
« Reply #6 on: May 09, 2020, 01:29:22 pm »
I don't like the thick black BNC cables which are expensive and poor quality. Some of my test gear has other connectors like N-Type and 7mm.  What I have done is buy converters to get everything to SMA female and then I have a stock of RG316 male SMA-SMA cables.  I also have a few semi-rigid male SMA-SMA cables that are good for GHz frequencies.
You might consider this as an option.
If at first you don't succeed, get a bigger hammer
The following users thanked this post: Someone, thm_w
Offline alm
« Reply #7 on: May 09, 2020, 04:21:59 pm »
I would be worried about SMA connector mating cycles when using them for everyday, jellybean connections. Especially if you not being careful when mating them. You can also get BNC cables with RG316 (or RG174) if you prefer the thinner cables.
Sure, BNC is not a good option for GHz frequencies, but the Siglent function gen is not going to get anywhere near that.
For straight cables I would definitely stick to 50 Ohm. But for alligator clips I'm not sure if it makes much of a difference. The impedance mismatch at the point where the coaxial cable changes to two flying leads might very well swamp the mismatch between coaxial cable and function gen. But sticking to 50 Ohm cables certainly doesn't hurt.
« Reply #8 on: May 09, 2020, 06:04:02 pm »
Ah, you guys in the USA have more choice, at a lower price!
Amazon UK doesn't have any cheap stuff - but I am thinking I'll go with a reasonable brand from a specialized electronics shop because I've been stung before (fake resistors).
« Reply #9 on: May 09, 2020, 06:05:52 pm »
Knowing the 50Ω stuff definitely helped, thank you!
I hope that's pretty much all there is to it (unlike scope probes that have a frequency rating as well).
Online nctnico
« Reply #10 on: May 09, 2020, 06:31:48 pm »
I second the suggestion to buy RG316 or RG174 BNC cables which are very thin and easy to work with. I also cut them up to have open ended cables to solder them to a circuit. I usually buy these kind of cables from RF Supplier (https://www.rfsupplier.com/ ). They are cheap enough to consider them consumables.
Online RoGeorge
« Reply #11 on: May 09, 2020, 06:32:22 pm »
Coaxial cables have many other ratings, too, e.g. maximum frequency, losses, velocity factor, etc. just that for your generator and your application (SDG 1032X, max 30MHz, no high power, not metrology only learning) almost any 50 ohms BNC cable will work just fine.
Offline eplpwr
  • Junior VoltNut
« Reply #12 on: May 10, 2020, 01:14:44 pm »
I've bought a couple of cables from:
https://www.koax24.de/en.html
They are not especiallly cheap, but have a large assortment and can do custom cables to order; I ordered some BNC-to-BNC (male both ends) with the Hyperflex 5 cable, since I have many other rather stiff coax cables. Also, this was the first place in Europe where I could find good triax cables (just the cable without connectors).
I do not have any business interest in the mentioned company, just a happy customer.
Offline NoisyBoy
« Reply #13 on: May 10, 2020, 03:27:59 pm »
I have both RG58 and RG316 cables, if it is your first set of cables, I prefer RG58 because it can stand up to a lot more abuse.
I only use Pomona for my cables (as long as they make what I am looking for), their RG58 is built so tough that if you accidentally pull on it, you will likely break the Siglent before the cable.  I have never had a single failure with Pomona in decades.
Offline Hydron
« Reply #14 on: May 15, 2020, 07:39:31 am »
I'm guessing you've never used their standard multimeter leads then, they are guaranteed to fail where they enter the probe handle due to ~zero strain relief on a very flexible cable. The super pointy tiny probes have different issues due to poor internal connections. A real shame as there's really nothing quite the same available elsewhere for the super pointy small ones, and the bigger ones are otherwise nice too and reasonably priced if you avoid the fluke branded versions.
Offline sequoia
« Reply #15 on: May 21, 2020, 06:54:31 pm »
I bought this set of cables:
  https://www.amazon.com/Micsoa-Leads-Alligator-Clips-Oscilloscope/dp/B07FZV589P/ref=psdc_5011673011_t3_B011GB13XO
Above ones seem to be out-of-stock, so I ordered following "Proster" leads to try out:
https://www.amazon.com/gp/product/B07K2MVB2D/    [$12.99 currently]
995609-0
For the money quality is pretty good, thin and flexible 50\$\Omega\$ coax, markings on the cable: ML SYV-50-2-41
(specs seem to be these: http://www.lianstar.com/en/SYV-50-cable.php)
« Last Edit: May 21, 2020, 06:58:56 pm by sequoia »
Offline Wallace Gasiewicz
« Reply #16 on: May 24, 2020, 03:12:05 pm »
You can make your own cables. I use RG 223 coax and good old fashioned Clamp connectors. There are various kinds of connectors. Stay away from the "screw on" type
Here is a link to you tube with a couple of videos on some RF BNC connectors by a real RF engineer
https://www.youtube.com/user/w8bya/videos
Wally
« Last Edit: May 24, 2020, 07:46:31 pm by Wallace Gasiewicz »
Offline james_s
« Reply #17 on: May 24, 2020, 04:20:22 pm »
I make my own cables these days. I bought 50' of RG316 from an ebay seller and a bunch of different crimp connectors. Got a ratcheting crimp tool and a couple of die sets, that was around $40 and now I can make nice clean RF cables of any sort I please.
