I have not personally used them, but the CT4200 probes seem to be a lower quality copy of the PMK 2.5mm probe line (
https://www.pmk.de/en/products/2_5_mm_tastkoepfe ) which is rebranded by several companies.
The external accessories should be compatible but the tips do not seem to be compatible. Also, the capacitance of the CT4200 probes seems to be higher and the injection molding quality looks lower.
I have used the PMK rebranded 2.5mm probes and can recommend them.
The PMK 2.5mm probes are rebranded and sold by Agilent, R&S, and Picoscope, amongst others. I think the picoscope one is the cheapest (but sometimes the R&S or Agilent probes can be found used on ebay for cheap). It might be worth the price differential
https://www.picotech.com/accessories/standard-passive-probes/500-mhz-scope-probe
