Author Topic: siglent sds1102dl wrong firmware update, so not function...  (Read 672 times)
Offline sonielkrafTopic starter
  • Country: id
    • acwirosari
« on: October 14, 2024, 12:25:30 am »
heloo everyone, my siglent sds1102dl was update firmware with sds1000cml, and then my scope is abnormaly...i need firmware sds1102dl, do you have? thank you
Offline coromonadalix
Re: siglent sds1102dl wrong firmware update, so not function...
« Reply #1 on: October 14, 2024, 12:36:50 am »
try to contact  member here   Tautech, he maybe can supply you with recovery procedures
OH you already did ...........
one attached
« Last Edit: October 14, 2024, 12:41:36 am by coromonadalix »
  • Country: id
    • acwirosari
« Reply #2 on: October 14, 2024, 12:41:54 am »
i was contact tautech, i send email , maybe he is busy...
« Reply #3 on: October 14, 2024, 12:45:48 am »
file is posted   check it
  • Country: id
    • acwirosari
« Reply #4 on: October 14, 2024, 12:52:25 am »
ok thank you, i try to update, please wait for result.....thanks...
  • Country: id
    • acwirosari
« Reply #5 on: October 14, 2024, 01:07:34 am »
thank you so much brother, my scope is back....but on ch2 any something, what happened? this is hardware problem?
Offline BillyO
« Reply #6 on: October 14, 2024, 11:24:58 pm »
If that scope has a self-calibration, try running it.
« Reply #7 on: October 15, 2024, 12:08:09 am »
No, it's a PBKAC issue.
Input couplings are unequal.
Do this ^ too.
« Last Edit: October 15, 2024, 12:10:49 am by tautech »
  • Country: id
    • acwirosari
« Reply #8 on: October 15, 2024, 02:30:34 pm »
I was try do self calibration, is same result, what happens Mr. Tautech,? Any solution?
  • Country: id
    • acwirosari
« Reply #9 on: October 15, 2024, 02:50:13 pm »
This is condition no probe, and zoom it, like ripple, not smooth
« Reply #10 on: October 15, 2024, 07:09:19 pm »
And probe input attenuation is set to what ?
10x ?
If so real input sensitivity is 100mV/div.
  • Country: id
    • acwirosari
« Reply #11 on: October 15, 2024, 10:12:55 pm »
Attenuation set to 1x, I try set 10x but no effect....
