Author Topic: Need Oscilloscope Probe Suggestions  (Read 238 times)
Offline Hootis TigglebitsTopic starter
« on: December 19, 2024, 06:49:12 pm »
I use a Rohde & Schwarz RTB2004 oscilloscope daily at work, but I've found their RT-ZP03S probes lacking in quality. The tips are too large for my applications, and they tend to only last 6 to 12 months. I'm looking for replacement probes that have the following specs similar to or better:
Bandwidth: 300 MHz
Dynamic range: 200V
Attenuation Factor: 10:1
Input Impedance: 1 MΩ // 39 pF
Connection: BNC
Probe with a tip diameter around 0.75mm, provisions for a ground spring and a clip smaller than the standard alligator style.
Can you recommend any probes known for their accuracy and durability that cost under $350 each?  Thanks in advance.
Offline KungFuJosh
  • TEAS is real.
Re: Need Oscilloscope Probe Suggestions
« Reply #1 on: December 19, 2024, 07:17:49 pm »
Take a look at probemaster.com
