Author Topic: can i use Agilent U1733C as a in circuit tester  (Read 3029 times)
Offline jtronixTopic starter
« on: November 16, 2012, 03:53:53 pm »
i'm going to buy LCR+ESR meter.
i have few question regrading this meter please help me
Is this meter use as in circuit measurement like in circuit capacitor and ESR measure (without desoldering from board)???
i also have interest in mastech MS5308. but i have same question is this meter measure in circuit measurement ???
Offline robrenz
  • Real Machinist, Wannabe EE
Re: can i use Agilent U1733C as a in circuit tester
« Reply #1 on: November 16, 2012, 04:05:02 pm »
AFIK in circuit test means the excitation voltage is low enough to not turn on any semiconductors, the 1733C is worst case .79V rms which would be 1.117V peak. I don't think this qualifies as in circuit test voltage level.  Even if it did you have to make sure other components are not going to effect the reading like another cap in parallel with the one you are testing.  There is no magic in circuit tester that can automatically give a valid reading no mater what.
« Last Edit: November 16, 2012, 04:07:43 pm by robrenz »
