Author Topic: Can you adapt keysight probes to other scopes?  (Read 666 times)
Offline ballsystemlordTopic starter
  • Student
« on: January 21, 2025, 02:42:48 pm »
Hello,
Wishing for an active probe, I looked online and found that many of the ones in the used market are keysight / agilent probes.
I understand that they have an interface that takes power from the scope, but can they work with a scope that has no special interface assuming you feed power to them?
I've seen successes with getting such probes working with "unsupported" scopes before, like here: https://www.eevblog.com/forum/testgear/agilent-1152a-active-probe-_smartprobe_-conversion-for-dsox3000-series-scopes/msg1029128/ just not "dumb" scopes yet.
Thanks!
PS: I'm talking about scopes with a 1Mohm input. I know the fancy keysights will have a nice 50ohm input.
« Last Edit: January 21, 2025, 02:56:32 pm by ballsystemlord »
Online tszaboo
Re: Can you adapt keysight probes to other scopes?
« Reply #1 on: January 21, 2025, 05:41:21 pm »
There used to be some adapters, but it's a walled garden now. You are expected to buy the same brand. Probe interface is proprietary, and they have EEPROMs with serial numbers to lock things down (and calibration data). Because probes make a lot more profit than scopes.
  • Student
« Reply #2 on: January 21, 2025, 05:54:38 pm »
Soooo maybe there's a list of (active) probes which are not a walled garden somewhere?
Thanks
Offline LaurentR
« Reply #3 on: January 21, 2025, 07:21:41 pm »
One decent option is the old Tektronix Tekprobe probes, which are plentiful at 1/10th retail price on EBay. You can get a P6245 1.5GHz active probe for about $200.
That's what I use on my Keysight scope (they have a special adapter for the old Tek probes) and have built a small collection of Tek active and differential probes.
For use with any scope, you can get a Tek 1103 power supply to connect them. It provides the supply and offset for most Tekprobe probes and has a 50 Ohm connection to get to whatever your scope is. You can also find those on EBay for a fraction of the retail price. IIRC, there are a couple of DIY options as well (search on this forum).
The following users thanked this post: ballsystemlord
Online tszaboo
« Reply #4 on: January 21, 2025, 08:21:38 pm »
Thanks
Micsig, for example. Testec. Picoscope sells also.
There is at least 3 members on this forum selling different types of active probes as well.
Offline artag
« Reply #5 on: January 21, 2025, 10:15:34 pm »
An HP1142A probe supply is the HP equivalent. A lot of older probes had an external supply like that (or the 1103) and ended in a normal BNC connector. Note that some of those probes expect 50 ohm termination at the scope.
The following users thanked this post: Someone, ballsystemlord, LinuxGuy123
Offline 44kgk1lkf6u
« Reply #6 on: January 23, 2025, 04:25:33 am »
What is wrong with an in-line terminator?
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #7 on: January 23, 2025, 03:15:37 pm »
We (R&S) also offer a special adapter for some Tek probes
https://www.tequipment.net/Rohde-&-Schwarz/RT-Z2T/Oscilloscope-Probe-Accessories/
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
  • Student
« Reply #8 on: January 23, 2025, 06:40:42 pm »
Nothing. I just wanted to be clear in case there are any "traps for young players".
