The voltage is .627 according to the meter, the volts/div is set to 1.
I expected the curve on the scope to only occupy about .62 of 1 box. I don't know what to call the gradient lines. The scope seems to see 2 volts ac. So where is it getting it ?
Thanks
What you are seeing is correct.
A sine wave with 2.0 V
P-P (Volts peak to peak) has a RMS value of 0.707 V
RMS. Other waveforms have similar relations: e.g. a 2.0 V
P-P triangle wave is 0.58 V
RMS. You may need to study what RMS voltage means in order to understand.
Your multimeter may read a little lower than the real RMS value depending on the frequency, as all multimeters have an upper limit and the response rolls off (decreases) above a certain frequency. This probably explains why it indicates 0.627 instead of 0.707. If you try a lower frequency (e.g. 50 Hz) then the reading can be trusted more.
