Author Topic: Any experience about Yokogawa DL 1200A or DL 1540 ?  (Read 2695 times)
Offline plazmaTopic starter
    • Homepage
« on: September 05, 2018, 12:50:59 pm »
There are some for sale for 140€. They are quite compact 4 channel scopes. Bandwidth is only 150 or 100MHz.
Offline Hydrawerk
Re: Any experience about Yokogawa DL 1200A or DL 1540 ?
« Reply #1 on: September 05, 2018, 01:00:56 pm »
The front panel is not a traditional one.
Offline abraxa
  • Sigrok associate
« Reply #2 on: September 05, 2018, 01:03:45 pm »
Yokogawa has a good reputation and those scopes are worth that kind of money in my opinion. However, the CRTs need to be checked for burn-in - if they have it, I personally wouldn't buy them.
Also, they may need replacement of the internal battery, described here: https://www.suwatsu.com/hobby/report/report_0002.htm
btw, if you don't have a use for two scopes, I'd look for a better deal for 280 Euro - you may get more bandwidth and samplerate this way.
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #3 on: September 05, 2018, 01:42:29 pm »
Yokogawa is very decent gear, owned a few over the years. But 200Msa is pretty poor for that 150MHz unit. Will probably be good for repetitive signals but for everything else your actual BW will be a *lot* less than the 150MHz advertized.
    • Homepage
« Reply #4 on: September 05, 2018, 01:48:58 pm »
I don't need more scopes but thought about hinting about these to local hobbyists. I already got Rigol DS1054Z, free DSOX 1102G and  a free Tektronix TDS7104.
