Author Topic: Can you Hack the Hantek DSO2D15 to go to 200MHz?  (Read 1754 times)
Offline Merlin11Topic starter
« on: July 08, 2024, 05:50:19 pm »
I just bought a Hantek DSO2D15 on Amazon hopefully it will get here soon. Can this scope be modded to run at 200MHz? I have searched the forum and I can't seem to find the answer. Does anyone know what the latest firmware is? Is there a how to for doing a full backing up of this scope? Thanks
Offline TomKatt
Re: Can you Hack the Hantek DSO2D15 to go to 200MHz?
« Reply #1 on: July 08, 2024, 06:27:10 pm »
I have zero experience with that scope (or Hantek products in general), but there is a lengthy thread on that series here - no idea what information is available, but I suspect that is where you'll find it.
Just curious - given your questions, what led you to purchase that particular brand/model?  Also it appears that scope is officially spec'd for 150MHz - do you really need the additional bandwidth?  I guess anything 'more' is 'better', but if you don't actually need it, why bother potentially mucking it up if it turns out to be complicated?
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline Aldo22
« Reply #2 on: July 08, 2024, 06:28:04 pm »
What do you mean by "hack"?
Normally you hack a scope to upgrade to a better (existing) version if the limitation is in the software
But there is no 200MHz version of the DSO2000.
However, this does not mean that the DSO2000 cannot display/measure 200MHz. The amplitude is simply lower and it becomes a little unstable.
The FAQ is here: https://www.eevblog.com/forum/testgear/hantek-dso2x1x-models-master-thread/
« Reply #3 on: July 09, 2024, 07:19:33 pm »
This scope seems to have the most bang for your buck and they seem to support it with new firmware updates so the scope seems to keep getting better.
« Reply #4 on: July 09, 2024, 07:26:37 pm »
I have seen a hack tool to  convert some slower Hantek scopes (70MHz 100MHz) to work at 200MHz. I would like to do the same with this new scope.
« Last Edit: July 09, 2024, 07:28:21 pm by Merlin11 »
Offline Aldo22
« Reply #5 on: July 09, 2024, 07:37:48 pm »
What you say makes no sense imho.
A scope does not "work at 200MHz" it has a bandwidth and a sampling rate.
Are you confusing that with overclocking?
Besides, 150MHz and 200MHz bandwidth are not a significant difference in practice.
Offline pcprogrammer
« Reply #6 on: July 09, 2024, 07:48:59 pm »
The 150MHz bandwidth limit is set in hardware, so no easy hacking it to do 200MHz, and even if you do manage to get the filters up to that higher bandwidth the sampling rate remains at max 1GSa/s when on a single channel or 500MSa/s when both channels are enabled. Even with the 150MHz bandwidth it is already pushing the limits of usefulness in signal versus sampling rate.
I reverse engineered the schematics of this scope, but did not measure the capacitor values, so no telling what the actual filter bandwidth is based on calculations. You can find the schematics here.
Offline radiolistener
« Reply #7 on: July 09, 2024, 07:50:21 pm »
Oscilloscope modification to make more wide bandwidth is a stupid idea. This is because oscilloscope frontend bandwidth is designed to fit with Nyquist border of ADC which is a half of sample rate. So if you extend frontend bandwidth, but keep the same sample rate, you will get more aliases and as result oscilloscope will be unable to show proper waveform for a complex signal which consists high frequency components.
Due to physical limitations of analog filters, there is a rule of thumb to use sample rate at least 10x times higher than required bandwidth. And since DSO2D15 has sample rate 1000 MHz, you're needs to limit input bandwidth to 1000/10 = 100 MHz. If you use more wide analog bandwidth your oscilloscope will suffers from aliasing issues.
Oscilloscope frontend modification to extend analog bandwidth from 100 MHz to 200 MHz may have sense if you're planning to use it to measure amplitude. But note that with such kind modification you cannot believe to waveform displayed on oscilloscope.
Such modification just make your oscilloscope defective and it cannot be used as a usual oscilloscope to check signal waveforms.
There is more sense to reduce analog bandwidth from 100 MHz to 10-20 MHz. It will give you some benefits, like lower noise and less waveform distortions. But usually oscilloscope already has a switch in the menu to reduce bandwidth, so there is no needs to "hack" it to get that benefits.
« Last Edit: July 09, 2024, 08:01:13 pm by radiolistener »
Offline Aldo22
« Reply #8 on: July 09, 2024, 07:59:57 pm »
pcprogrammer and radiolistener are right.
That said, you can measure a 200MHz sine frequency even with the 100MHz variant (DSO2C10).
The measured amplitude is just too low (useless value).
This cannot be improved with a "hack" afaik.
« Last Edit: July 09, 2024, 08:10:24 pm by Aldo22 »
« Reply #9 on: July 10, 2024, 04:02:35 pm »
There are Hantek scopes that are made to run at 200MHz but have had there speed restricted in firmware. Iam asking if this scope is one of those and if so can the restriction be removed. I other words if this scope is hobbled I want to un-hobble it.   :-//
Offline Aldo22
« Reply #10 on: July 10, 2024, 04:13:09 pm »
This question has already been answered.
Do you even read the answers?
Offline indman
  • Country: by
« Reply #11 on: July 10, 2024, 04:26:35 pm »
For example, I have model DSO5202P and DSO5201P. The first model has an analog bandwidth of 200 MHz, the second model - 100 MHz. The sampling frequency of both models is 1 GHz. I need to measure the amplitude of a simple sine wave with a frequency of 150 MHz. Which model is better for this task? It is clear that the first model will give a more correct measurement and not just observation of the signal shape and its presence. So your conclusion is controversial. ;)
« Reply #12 on: July 10, 2024, 05:34:03 pm »
both, just use different correction coefficient
Offline indman
  • Country: by
« Reply #13 on: July 10, 2024, 05:41:03 pm »
Didn't understand? The DSO5202P claims signal level -3db at 200 MHz. This is not standardized for the DSO5102P, what coefficients should I use? This is not serious!
« Reply #14 on: July 10, 2024, 07:59:32 pm »
Yes I've read the answers. Iam just not sure you understood the question. No need to keep posting in my thread.
Offline Gyro
« Reply #15 on: July 10, 2024, 08:03:33 pm »
It's not your thread, that's not the way things work here.
Best Regards, Chris
Offline Aldo22
« Reply #16 on: July 10, 2024, 08:37:34 pm »
OK, I'll try again.
No.
No, it's not.
The only thing you can "hack" is to activate the AWG, if it is not already running and some CPU overclocking.
« Last Edit: July 10, 2024, 08:43:26 pm by Aldo22 »
« Reply #17 on: July 10, 2024, 09:55:18 pm »
I got it. I was just making sure I hadn't missed something.
« Reply #18 on: July 23, 2024, 04:06:18 pm »
Can anyone tell me what the latest firmware for my DSO2D15 is?
Offline Aldo22
« Reply #19 on: July 23, 2024, 04:24:24 pm »
« Reply #20 on: July 23, 2024, 06:42:21 pm »
I have downloaded the latest from Hantek Iam not sure what ver number is from the file name. My scope is running ver 3205 does anyone know the number of the latest? I don't want to try installing a older ver or even the the same ver if it is ver 3205. If there is a newer one what would the advantage be of installing it? Thanks
Offline Aldo22
« Reply #21 on: July 23, 2024, 06:47:07 pm »
It's all in the FAQ that I linked above in my first answer.
« Reply #22 on: July 23, 2024, 08:23:37 pm »
That's the file I downloaded but what ver is it As I posted my ver is 3205 and I don't know how to extract the ver number from that file as I posted above.  |O
