Author Topic: Can you use normal oscilloscope probes on a spectrum analyzer?  (Read 1491 times)
Offline cvancTopic starter
Hi all-
Will using normal oscilloscope probes work on a spectrum analyzer?
Thank you.
Offline nctnico
Re: Can you use normal oscilloscope probes on a spectrum analyzer?
« Reply #1 on: March 31, 2023, 02:03:44 pm »
Assuming you intend to use a spectrum analyser with 50 Ohm inputs only:
The High-z 1:10 probes: no
But Low-z high frequency probes (like the Tektronix P6156), which are designed to work with a 50 Ohm input, work well on a spectrum analyser but be aware of DC level limits
Offline alm
« Reply #2 on: March 31, 2023, 02:39:31 pm »
Many active probes, especially the higher frequency single-ended and differential probes, are also designed to work in 50 Ohm inputs, so should work fine assuming you can power them. Some manufacturers made/make separate probe power supplies that could be used to adapt their probes to a spectrum analyzer.
You might want to put a DC block between probe and spectrum analyzers, since these probes are DC coupled and most spectrum analyzers do not like DC at their input.
Offline Wallace Gasiewicz
« Reply #3 on: March 31, 2023, 05:47:36 pm »
I use 10 X Scope Probes on my HP 8935 Antenna Input for Spectrum Analyzer very frequently. It works well for relative amplitude,A lot safer for the equipment than using straight leads or a 1X probe.
I do not think Calibration of the magnitude is accurate.
Offline alm
« Reply #4 on: March 31, 2023, 07:29:49 pm »
The attenuation will vary over the bandwidth, so while it will show a signal, just like holding a bare wire close to the signal source will show a signal, it won't be an accurate representation.
