Author Topic: Rigol DG4000: issue with output level of modulated signal  (Read 2140 times)
Offline madiresTopic starter
  • A qualified hobbyist ;)
« on: December 21, 2016, 01:54:06 pm »
If you're looking for a signal generator for RF stuff the following might be interesting to avoid buying the wrong tool:
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
Re: Rigol DG4000: issue with output level of modulated signal
« Reply #1 on: December 21, 2016, 11:36:05 pm »
I agree. Mike was pretty unhappy with it. It has and  does all the functions But that output issue was strange.
Offline Orange
« Reply #2 on: December 23, 2016, 10:38:57 am »
My Rigol DG4102 does the same on AM modulation !
My Siglent SDG1062X does the same on AM modulation !
On my HP8657B I don't have this issue, but that is a real RF signal generator.
Moral of this story : Know your Test Equipment limitations
Offline Marc M.
« Reply #3 on: December 24, 2016, 02:52:37 pm »
Having done a 3+ year stint as a bench tech back in the heyday of CB, I have a lot of respect for Mike and his work. That said, I found it a little odd that he would purchase a function gen. to use as an RF generator :-//. It certainly shouldn't have the kind of error it does (which Rigol seems to be calling a feature  ::)), but I also wouldn't expect it to be a suitable replacement for an RF generator.  There's a reason RF generators are $$$$$$ and function generators are $$. Because of his unrealistic expectations, I feel his harsh criticism is a little unfair to Rigol.
Don't replace the cap, just empty the filter!
