Hello swperk: Remember - Your USB Pen, Stick, etc MUST BE LESS than 1 GB. I have used 256 MB and 512 MB (both FAT32). Maybe you have forgotten this.
Also remember I said DO NOT Install the Boot Loader twice. If you do, or have done it, then that may the reason for your problem(s). And if so, time for your unit to go back to mama Rigol. We should try to understand this. From what Rigol has said I figured it possibly wouldn't start at all if the Boot Loader was installed twice, but perhaps your issue could also be a symptom of this(?).
Does your unit currently work with its version 11 firmware? If it does then there is still hope for it. If its not currently working, and not within its warranty then you will be responsible for the shipping costs both ways. If it is within the warranty then your only responsible the shipping to Rigol.
By the way I never thought that v. 14 firmware would load into your unit if v. 12 wouldn't, I just wondered why you weren't trying to load the current firmware in it. I didn't realize at the time that Rigol is no longer listing v. 14 firmware. I guess - no Rigol surprise here!
Please give us a clear description of the current operational status, what all you have done.
Ted
TurboTom - Tom, do you have any suggestions for swperk? If so please comment because you are very knowable of Rigol products and the DG4000. Thanks for anything you can add, or please correct anything I have said that may be wrong, or misleading.
Have you ever seen v. 11 firmware, as I have not. Thanks, Ted
