Author Topic: Rigol DP811 USB dead?  (Read 269 times)
Offline terranceTopic starter
« on: September 16, 2024, 08:21:38 am »
Insert any UFD, USB2, USB3, SD Card reader... nothing works. Tested the connector, has 5V supply, D+ D- appears ok, with 20k resistance to V-.
Insert UFD when powered up, no D: appears.
Removed LAN cable, still not working.
Am I doing something wrong? Or is there a known working UFD list, or what?
« Last Edit: September 16, 2024, 11:30:54 am by terrance »
Re: Rigol DP811 USB dead?
« Reply #1 on: September 16, 2024, 03:04:22 pm »
My USB2 UFD has an LED, It does not blink at all, so the DP doesn't even try to enumerate it?
Offline _Wim_
« Reply #2 on: September 16, 2024, 07:35:35 pm »
Did you use FAT32 formatting? What memory size where they? I believe (not sure) they should be <8GB.
« Reply #3 on: September 20, 2024, 09:12:59 am »
absolutely, usb 2, fat32, 4GB, and my DM3068 can use it....
Offline _Wim_
« Reply #4 on: September 20, 2024, 05:54:18 pm »
That does indeed sound like the USB port has issues in that case. Do you see any traffic on D+ and D- when you plug a stick into the port?
