Products => Test Equipment => Topic started by: 4thDoctorWhoFan on May 28, 2023, 04:00:34 pm
Title: Capacitor comparison Sencore LC101, DE-5000, Agilent 4263B
Post by: 4thDoctorWhoFan on May 28, 2023, 04:00:34 pm
In case anyone is interested, I attached a file showing the capacitor measurements between a Sencore LC101, DE-5000 and an Agilent 4263B.
The capacitors are from an ARCO kit of capacitor standards.  All caps are rated for .1%
This is just a quick comparison and nothing super scientific.  :-+
Title: Re: Capacitor comparison Sencore LC101, DE-5000, Agilent 4263B
Post by: mawyatt on May 28, 2023, 06:42:09 pm
Nice capacitor kit, where does one find such a quality kit?
Good agreement on all 3 LCR meters :-+
Best
Post by: 4thDoctorWhoFan on May 28, 2023, 07:58:00 pm
Best
I found this kit on ebay years ago.  The wooden box the caps came in was falling apart and the foam on the inside was disintegrating.  Luckily, the caps themselves were still in good shape.
Post by: mawyatt on May 28, 2023, 09:08:48 pm
Wow that's from way back, seems they are using "mmF" or micro-micro-farad for pF ::)
Looks to be Bakelite encased, likely with Silver Mica capacitors?
Best,
Post by: Martin72 on May 28, 2023, 09:24:25 pm
At 1khz, all LCR meters I tested were very close.
Only at 10khz and above it gets interesting. ;)
Post by: TimFox on May 28, 2023, 09:51:11 pm
Best,
Actually, Arco quoted small values in mfd, e.g. 0.0001 mfd, in their description on that advertisement.
Back then, we called mmf "mickey-mikes".
I believe Arco specialized in silver mica capacitors.
Post by: 4thDoctorWhoFan on May 29, 2023, 12:47:08 pm
The DE-5000 really does a great job especially considering the Agilent will cost you a arm & a leg.
The Sencore is okay.  The resolution is a little lacking & I have no idea what frequency is being used.
