Yes it is a good upgrade certainly for the voltage, somewhat less useful for the current.
You can use a multiturn pot or add a second 'normal' pot that will handle the fine adjust (about 1/10 or 1/20 the resistance of the original pot).
Which method is better for you is more a question of preference. The 2 pot solution is somewhat quicker but less elegant.
