Author Topic: Cheap bode plot device...  (Read 11007 times)
Offline David Aurora
Re: Cheap bode plot device...
« Reply #25 on: August 25, 2022, 10:11:06 pm »
I also have a Analog Discovery 2. No idea if it can do bode plot (it should, I think)
It can, and the Digilent software will even do it via your sound card at audio frequencies.
Did not know Waveforms worked with other hardware, will be trying this at work today! That could be super handy for callouts to studios
EDIT- Actually... thinking about this I think I DID know this, but had issues with it and didn't go any further. Will try again either way
« Last Edit: August 25, 2022, 10:27:36 pm by David Aurora »
Offline Warpspeed
« Reply #26 on: August 25, 2022, 11:08:39 pm »
@Mawyatt
Yes indeed, many ways to skin a cat.
From the completely nerdy software/mathematical approach, to the down and dirty nuts and bolts hardware approach.
I am at home and retired a long time ago, plenty of time on my hands, and this project is mainly a time filler, something I have been thinking about doing for a very long time..
Also, have a lot of hardware here, remnants of a lifetime of messing about with home brew amateur radio. So the tracking filter approach has a lot of appeal, and is something I feel very confident of achieving good results with.
I also have quite a few very nice 100Khz vacuum mounted crystals of Russian origin, that are perfect for a pair of matched super sharp bandpass filters.
Its all coming together quite nicely too, and there have been far fewer problems than I expected.
Its becoming a rather interesting project.
« Last Edit: August 25, 2022, 11:30:40 pm by Warpspeed »
Offline JeremyC
« Reply #27 on: November 04, 2022, 05:35:14 pm »
Can you guys recommend any cheap device that can do bode plotting for audio frequency (20Hz-20kHz)?
If you are working with audio, you may find interesting links below:
  - RightMark audio analyzer, https://audio.rightmark.org/index_new.shtml
  - REW, https://www.roomeqwizard.com/
I also have a Analog Discovery 2. No idea if it can do bode plot (it should, I think) but it is annoying to have to have a laptop every time I want to use it.
Yes, the AD2 has Bode plot option, in the WaveForms it’s called “Network”, check the link, it may give you some ideas.
