Products => Test Equipment => Topic started by: IAmBack on February 06, 2017, 07:47:10 pm
Title: Cheap sound level meter/logger
Post by: IAmBack on February 06, 2017, 07:47:10 pm
Hello.
I need a cheap sound level meter to make some environmental tests. I want to register the sound level values, so chosen device should have data logging function - at least via USB port.
I've found two devices that are appealing:
http://www.ebay.com/itm/Digital-40-130-dB-Sound-Pressure-Level-Noise-Meter-Decibel-/311569908935?hash=item488b0384c7:g:3rEAAOSwAYtWPCWk (http://www.ebay.com/itm/Digital-40-130-dB-Sound-Pressure-Level-Noise-Meter-Decibel-/311569908935?hash=item488b0384c7:g:3rEAAOSwAYtWPCWk)
http://www.ebay.com/itm/30-130dB-USB-Digital-Sound-Pressure-tester-Level-Meter-Decibel-Noise-Measuremen-/131294341397?hash=item1e91c0a915:g:QG4AAOSwmmxW4Q7p (http://www.ebay.com/itm/30-130dB-USB-Digital-Sound-Pressure-tester-Level-Meter-Decibel-Noise-Measuremen-/131294341397?hash=item1e91c0a915:g:QG4AAOSwmmxW4Q7p)
There is small visible difference between them - one is supplied from 4 AA batteries, the second one uses 9V battery.
Both are at price range below 30USD. I don't want to spend more than 40 USD. Free shipping welcome :)
Does anyone has experience with the pointed devices (is one superior to the other) or can point me to the other options.
Regards.
Edit: it looks that 9v version uses some weird usb cable with on chip to do  usb-serial conversion.
