Author Topic: cheap tek 500MHz passive probes on ebay. can they be used on any scope?  (Read 10326 times)
Offline JPorticiTopic starter
this auction, that might interest somebody
http://www.ebay.it/itm/TEKTRONIX-P6139A-Oscilloscope-Passive-Probe-/282176061341?hash=item41b300ff9d:g:tv0AAOSwmLlX2QcD
seemed a bargain.
i bought one to try if it is any good, but i have no idea if it needs a tektronix scope with readout system to work.
does it, or i can use it with whatever scope as a simple probe?
Offline PA0PBZ
Re: cheap tek 500MHz passive probes on ebay. can they be used on any scope?
« Reply #1 on: September 16, 2016, 11:45:47 am »
Look at the compensation range of the probe (8 to 18 pF in this case) and make sure that the scope you want to use has an input in this range.
Offline TimFox
« Reply #2 on: September 16, 2016, 03:40:34 pm »
Typically, the capacitance at the CRO input is stated on the panel, near the BNC input.
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #3 on: September 16, 2016, 03:51:29 pm »
The sense resistor values that scopes use to determine attenuation settings are typically standardized across manufacturers. Like PA0PBZ said, you'll want to check the compensation range and make sure they're compatible.
Active probes are a different story.
Offline dav
« Reply #4 on: September 16, 2016, 04:49:39 pm »
So does it work on a Agilent/Keysight DSOX3054X series scope?
Offline TheSteve
  • Living the Dream
« Reply #5 on: September 16, 2016, 04:52:30 pm »
Yes they should work and auto detect 10x properly.
VE7FM
Offline dav
« Reply #6 on: September 16, 2016, 05:00:26 pm »
On DSOX3054 front panel I can read:
1 Mohm  15pF
P6139A probe:
10 Mohm 8pF
compensation range: 8pF to 18pF
So is it ok? (no matter about the 10 Mohm input impedance?)
Offline TheSteve
  • Living the Dream
« Reply #7 on: September 16, 2016, 05:04:49 pm »
1 Mohm  15pF
P6139A probe:
10 Mohm 8pF
Yes, it will compensate just fine.
VE7FM
Offline dav
« Reply #8 on: September 16, 2016, 05:08:49 pm »
Offline rf-loop
« Reply #9 on: September 17, 2016, 09:07:55 am »
1 Mohm  15pF
P6139A probe:
10 Mohm 8pF
Scope input BNC  1Mohm 15pF (+ something)
Probe (low frequency) compensation range 8pF - 18pF.  (this is for scope input capacitance)
This probe tip parameters are  10 Mohm 8pF.
This have nothing to do with this matching with scope input.
So, yes, low frequency compansation range is ok for this scope input.
Sidenote:
when you measure some circuit,  mostly you can forget this 10Mohm.
But do not forget in RF circuits that you connect 8pF capacitor in circuit.
Yes better than 20pF or 16pF but still 8pF is LOT of in many cases.
@500MHz it have 39.8 ohm reactance, not 10Mohm what is DC resistance.
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Online tggzzz
« Reply #10 on: September 17, 2016, 09:59:52 am »
Very true.
It is also worth pointing out to beginners the effect the ground lead will have; a 6" ground lead will be about 140nH, and that will resonate with the tip capacitance at ~100MHz.
I've managed to reduce that inductance by copying techniques used in HP probes. FFI see https://entertaininghacks.wordpress.com/2015/04/23/scope-probe-accessory-improves-signal-fidelity/
EDIT: updated results at higher frequencies at https://entertaininghacks.wordpress.com/2016/09/17/scope-probe-accessory-higher-frequency-results/
« Last Edit: September 17, 2016, 04:54:39 pm by tggzzz »
« Reply #11 on: September 17, 2016, 05:29:33 pm »
 :clap:
love me dat blue phosphor
Online tggzzz
« Reply #12 on: September 17, 2016, 06:01:09 pm »
:clap:
Tek 485s are sweet little scopes in more ways than one!
There's a working one for sale on fleabay at the moment (no affiliation): http://www.ebay.co.uk/itm/Tektronix-485-two-channel-350MHz-analogue-oscilloscope-/282171555562
20 hours left :)
« Reply #13 on: September 17, 2016, 06:13:49 pm »
too bad my money is constantly feeding my 7k addiction!
Online David Hess
  • DavidH
« Reply #14 on: September 17, 2016, 09:08:36 pm »
When you get somewhere above 200 MHz with high impedance passive probes, the high frequency transient response of the probe is matched to the oscilloscope input so not all 500 MHz probes will deliver optimal response with all 500 MHz inputs.  You can see this in the old Tektronix probe recommendation guides where specific probes are recommended for specific oscilloscopes and "A" or "B" revision probes will be recommended for later oscilloscopes of similar or equal bandwidth.
High bandwidth general purpose probes have 2 or 3 user accessible high frequency adjustments besides the compensation adjustment so with a suitable signal source, they can be adjusted to work with any high bandwidth oscilloscope input.
Most people do not have a suitable signal source so not only will they not be able to adjust such a probe, they also will not be able to verify that a more specific probe is not working correctly and in most cases, the differences are not going to matter because the effect of the probe's input impedance will affect the signal that much anyway.  The probe and oscilloscope specifications depend on an unrealistic 25 ohm source impedance but the designers had to pick something as an objective reference.
Online tggzzz
« Reply #15 on: September 17, 2016, 09:32:35 pm »
All valid points.
I did tweak all the HF adjustments in the Tek probe, unsurprisingly.
I'm content if beginners merely realise that morning technique significantly affects the waveforms, how to recognise some effects, and some of the measures that can be taken to minimise the consequences.
Offline KE5FX
    • KE5FX.COM
« Reply #16 on: September 18, 2016, 06:19:32 am »
Watch out with the P6139A probe.  Unless they've had their cables replaced, they had a whisker- or dendrite-growth problem in the cable that will short out the signal and drive you nuts.  It can be cleared by running some current through the BNC connector but only temporarily.  The only fix is to order a new cable from Tektronix, which I'm not sure you can still do.
The following users thanked this post: rf-loop
Online tggzzz
« Reply #17 on: September 18, 2016, 07:32:16 am »
Interesting!
Have you considered adding that to http://w140.com/tekwiki/wiki/p6139 ?
Offline KE5FX
    • KE5FX.COM
« Reply #18 on: September 18, 2016, 07:56:50 am »
Interesting!
Agreed, could be worthwhile when I have time to sign up for an account on there.  It's not clear how widespread the problem is, or what serial #s are affected, but the problem is real enough.  It's bitten me and at least a couple of other people who got their probes from different sources at different times.  Very frustrating, because they are otherwise nice probes.
« Reply #19 on: September 19, 2016, 05:03:02 pm »
Interesting.
Anyway, mine arrived today. Seems to be working. The probe interface talks to my TEK7704A and informs the readout system that this is a 10x probe.
Thanks to tolerances, the capacitance is just enough so i can compensate the probe on a 7A22 7A26 (1M, 22pF)
Unfortunately i don't have faster plugins at the moment.. and IIRC they all are 50 ohm input.
The fastest signal i have around here is still the 2ns rise time trigger output from another scope and probing it is consistent with what i get using directly a (terminated) piece of coax.
the accessories in the pouch will be put in use very soon.
Not bad for 50 euro total :)
« Last Edit: September 19, 2016, 07:40:39 pm by JPortici »
Online tggzzz
« Reply #20 on: September 19, 2016, 05:11:30 pm »
Interesting!
It all sounds vaguely similar to the known problem with the delay line in HP1740A scopes. There, if you notice the risetime has risen from 3.5ns to 7ns, don't bother to tweak the controls as stated in the service manual. Instead, get your hand deep into the scope, and simply fondle, massage and squeeze the delay line.
Online David Hess
  • DavidH
« Reply #21 on: September 19, 2016, 05:31:50 pm »
Thanks to tolerances, the capacitance is just enough so i can compensate the probe on a 7A22 (1M, 22pF)
The 7A22 is 1M and 47pF.  My common 100 MHz x1/x10 probes are only rated to about 33pF but barely make it to 47pF.  My faster 250 MHz x10 probes do not have enough range to work with a 47pF input.
The fastest common high impedance amplifier is the 7A26 dual trace at 200 MHz.  The single trace 7A16A is 225 MHz.  The four trace 7A42 is 350 MHz.
Above 200 MHz, 50 ohm inputs are not that much of a disadvantage because the capacitance at the tip of a high impedance probe is a significant limitation at high frequencies.  A x10 or x100 50 ohm probe has a higher input impedance at high frequencies although not at DC.
« Reply #22 on: September 19, 2016, 07:40:12 pm »
7A26, sorry! i tested with a 7A26
Online MarkL
« Reply #23 on: September 20, 2016, 02:33:25 pm »
These are nice probes.  I have a set of 4 myself.
The only thing I would add to what's already been said is that the tips are rather delicate.  I've broken several.  And not the metal tip itself.  The plastic that holds the tip can crack or become loose and then the tip falls out.  I think I was not being careful enough putting on the sprung hook or rotating the hook too much.
The tips alone are not replaceable.  They come as a cartridge along with the input resistor and are expensive (qty 1 $45 at testpath.com, for example).
« Reply #24 on: September 20, 2016, 06:30:56 pm »
These probes are sold for 45. Grab some :D i will if there are more
(The seller contacted me before to ask how they were going. I'm not sure how to interpret that ::D)
Offline dbator
« Reply #25 on: September 19, 2024, 04:45:31 pm »
Hello,
Is that a confirmed information? Does that happen often? Is it possible to estimate the probability? Or maybe only counterfeit probes (if there are any on the market) are affected? I wouldn't want to spend about 100 USD for one probe and then throw it out. And I need 4 pcs.
I'm asking because I am about to purchase probes for my scope for which P6139A probes from Tektronix are recommended (capacitance of inputs on my scope is 13 pF). They are obsolete, but still available (second hand). I found some for sale on ebay, but from China which makes me suspicious.
I would purchase new probes from Testec, TT-HF-612 or TT-HF-612RA (with readout attenuator) instead, if they did not cost as twice as the P6139A.
Of course P6139B probes from Tektronix are available as new, but much more expensive than Testec probes, so too expensive for me.
Online MarkL
« Reply #26 on: September 19, 2024, 09:12:45 pm »
I have thirteen P6139A probes, nine of them purchased used.  In purchasing the used ones, I encountered two that had internal shorts, possibly from the whisker issue that KE5FX mentions.  The resistance on both indicated the short was at the probe end, so it could have also been the tip cartridge and not the cable; I don't know.  They were returned to the seller for a refund without further investigation.
At any rate, that was 5 years ago, and the nine I kept are still working fine.  The other four I bought new 25 years ago, and they are fine too.
So... I think the P6139A is ok to buy as long as you have a return option.  I would also try to get ones with as many accessories as possible (ground clip, sprung hook, color rings, etc. - see the manual) as genuine accessories can get expensive to buy individually.
