But it is in Asia.
Matter of time..... the youth is also getting tired of being drilled
http://www.globaltimes.cn/content/879187.shtml
re: Matter of time..... the youth is also getting tired of being drilled
Of course some are. First generation build it via hard work, second generation had the experience of seeing how it was done, but third generation got the benefit without even seeing what it took to build it. If they failed to educate their youth as we had, then their youth will also loose their ability to compete. They will see themselves decline as we (in the USA) are experiencing right now.
Many if not most youth in the developed world hadn't seen what it took to get to what we have. Everybody merely wants a piece of the pie but without the slightest of idea of the needs to earn it. Listen to all the cries about "living wage", did you ever hear about making a contribution worthy of a living wage?
Equal outcome are on of the ideas that China abandoned with Deng Xiaoping ("black cat white cat" quote, and "getting rich is..." ). And with the Cultural Revolution in far memory, they even stepped back from force volunteerism. It may even be accurate to say "Send Down Youths" is now a thing of the past. Whereas, some high schools here in the USA still require "community work", "volunteer points", etc. for graduation. They are moving away from the failed ideology whereas we are heading deeper into it.
If we don't change course to compete, we can only hope they change course back to non-performance as that would be the only way
for us not to be left behind alone. But having company in a desolate economy still doesn't make it better now, does it?
Rick
