Author Topic: Chinese oscilloscopes with 12 bit AD converter in the analog front-end  (Read 23724 times)
Online pascal_swedenTopic starter
  • Country: no
Owon has launched an oscilloscope with a 12 bit AD converter:
http://www.owon.com.hk/products_info.asp?ParentID=57&SortID=87&ProID=182#sthash.EhjBvy98.dpbs
What about the other Chinese/Taiwanese manufacturers? (Rigol, Siglent, GW-Instek)
Does anybody know another Chinese or Taiwanese company besides Owon that produces an oscilloscope with a 12 bit ADC?
How come that most Chinese oscilloscopes only have an 8 bit ADC, while most AVR microcontrollers already have a 10 bit ADC? I understand the sample rate is lower on these microcontrollers, but still, why do they expect a higher vertical resolution in microcontroller applications?
Regarding High Resolution mode on the Rigol scopes:
How is it implemented? By averaging or by oversampling? Or any other techniques?
I found some related documents that are good background reading on this subject matter:
Silicon Labs - Improving ADC Resolution by Oversampling and Averaging:
https://www.silabs.com/Support%20Documents/TechnicalDocs/an118.pdf
Actel - Improving ADC Results Through Oversampling and Post-Processing of Data:
http://www.microsemi.com/document-portal/doc_view/131569-improving-adc-results-white-paper
Agilent - Evaluating High-Resolution Oscilloscopes:
http://cp.literature.agilent.com/litweb/pdf/5991-1617EN.pdf
Analog Devices -  Pushing the State of the Art with Multichannel A/D Converters:
http://www.analog.com/library/analogDialogue/archives/39-05/multichannel.pdf
« Last Edit: December 05, 2015, 06:38:12 pm by pascal_sweden »
Offline marshallh
    • retroactive
Re: Chinese oscilloscopes with 12 bit AD converter in the analog front-end
« Reply #1 on: December 05, 2015, 08:09:59 pm »
It's cheap and relatively easy to throw on a 12 or even 14bit SAR ADC, the flipside is they are very slow (usually not much faster than 1Megsample/second). Just takes 1 comparator.
Basically all DSOs use flash ADCs - a large resistor network and many comparators. They use quite a bit more power, take up more die space and so are more expensive. But you can clock them (most fast ones are heavily pipelined synchronous) into the Gbps range.
Internally many faster ADCs use 2 or 4 or more individual flash ADCs interleaved to give a faster apparent speed. However this introduces additional problems - either the ADC or you have to compensate for gain/offset mismatches and sampling phase delays (not all bits are coming out at the same time).
I think probably Owon has either bought up a large quantity of some major manufacturer's 12bit stock at a cheap price, or they hired a chinese fab to do a die clone of the chip.
It's also possible that its just typical Chinese marketing, where it's a 8bit converter but does averaging at lower speeds.
Verilog tips
BGA soldering intro
Offline Alfons
« Reply #2 on: December 05, 2015, 08:27:40 pm »
"12 bits" is at first marketing screaming. If you want to make 12-bit really usable, the whole thing has to be constructed in accordance with quality around it. And that is very expensive. The units from China are not bad, as long as they move at a normal level. They always lag behind a bit and then bring equipment at very good prices. This can the Chinese perfectly. If they would not only look at the profit and a bit more would be innovative, they could really teach all fear.
Offline commie
« Reply #3 on: December 05, 2015, 10:06:48 pm »
with 8 bit flash you need 256 comparators. 12 bit you need 4096 comparators and given each comparactor contains about 30 transistors that's 4096x30=122880 transistors approx. for 12 bits. :scared: Ooops, needs an encoder aswell.
« Last Edit: December 05, 2015, 10:23:17 pm by commie »
Online nctnico
« Reply #4 on: December 05, 2015, 10:11:10 pm »
Just for fun calculate the jitter requirement to sample 12bit for a 200MHz bandwidth. I doubt the clock in the Owon oscilloscope is that good!
Offline rf-loop
« Reply #5 on: December 06, 2015, 03:04:17 am »
quessing
Truth: (And well explained in other thread.)
Owon XDS3102A (A=12bit model) ADC is Analog Devices / Hittite Microwave Corporation HMCAD 1520
Inside scope:
So, why speculate this and that.
« Last Edit: December 06, 2015, 03:42:17 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Offline amyk
« Reply #6 on: December 06, 2015, 03:24:57 am »
Those 10-bit ADCs are orders of magnitude slower too.
  • Country: no
« Reply #7 on: December 06, 2015, 12:58:09 pm »
So the scope really has a 12 bit AD converter?
What about the jitter on the clock?
Does anybody on this forum have such an actual scope from Owon, and if so, are you willing to do some measurements on it, to check how it performs.
Or if Owon is reading this, can you ship the 12 bit AD converter model with 200 MHz BW to Dave Jones, for a full review video? =)
Offline rf-loop
« Reply #8 on: December 06, 2015, 01:30:26 pm »
After ADC datasheet still question, why?
Around 2 months ago   there was available models XDS3102 (8bit 100MHz) and XDS3102A (8/12bit 100MHz).
I do not have more new information.
Yes, I have one XDS3102A with options Wi-Fi, TOU, and VGA.
There is other thread with some tiny tests just after I get it. After then I have been out from work nearly 2 months. So not yet made more tests .  Also it need note that when I get scope it have very early FW. (1.0.0.0)
Offline robert_
« Reply #9 on: December 06, 2015, 01:56:33 pm »
Would be interesting to see how good it really performs. I sort of would have expected some other major manufacturer would be the second one to go 12bit, not a 3rd tier chinese... Interesting nonetheless.
I did have the opportunity to get my hands on a real 12bit scope (HDO6k series), and it really IS a huge improvement. 10x vertical zoom doesnt result in excessive noise (<1div) at full 500Mhz and with no filtering needed...
Online Kleinstein
« Reply #10 on: December 06, 2015, 02:34:42 pm »
From the ADC's datasheet, the ADC is considerably (e.g. 20 times) slower in 12 Bit mode than in 8 Bit mode. This is still better than oversampling. So noise can be lower, but only about a factor of 4 at best - not a factor of 16 as you might expect from 4 extra bits.
Noise also depends on the input amplifier - usually at the highest amplification this is setting the noise limit, not the ADC.
  • Country: no
« Reply #11 on: December 06, 2015, 05:19:47 pm »
That's probably why they have provided the menu option to switch between 12 bit mode and 8 bit mode.
But does the vertical resolution affect the memory depth?
My understanding was that the memory depth only relates to the time period which you can record.
Or do they store two 12 bit samples as three 8 bit samples internally in memory?
Offline Neganur
« Reply #12 on: December 06, 2015, 09:43:19 pm »
It's definitely not 12-bit at 2GSa/s. That ADC can only do 500 MSa/s at 12-bit.
It's a lot of "maximum....", "up to....." put together in a summary.
EDIT: I like the ability to select higher bit rates at lower speeds tho, wonder why it doesn't take full advantage of the 14-bit for some 250 MSa/s stuff.
« Last Edit: December 06, 2015, 09:47:07 pm by Neganur »
Offline rf-loop
« Reply #13 on: December 07, 2015, 04:23:19 am »
Yes, it is of course not 2GSa/s. Models XDS3102 and XDS3102A are max 1GSa/s 100MHz models.
Without A it is 8bit  max 1GSa/s.  Model A is max 1GSa/s 8bit  and max 500MSa/s 12bit.
In these preliminary tables can see 8bit and 12bit  first 1 channel in use and next table 2 channels in use.
(note: these are tested with very first 1.0.0.0 FW)
wfm/s speeds are average speeds, not short time peak values what are perhaps used in advertisements.
« Last Edit: December 07, 2015, 04:28:08 am by rf-loop »
  • Country: no
« Reply #14 on: December 07, 2015, 01:30:03 pm »
@rf-loop: In your profile it says that your home country is China. But in the footer of your postings it says that you are reseller in Finland. Can you provide more details? How come you have all these detailed tables from Owon? =)
Offline rf-loop
« Reply #15 on: December 07, 2015, 03:50:44 pm »
@rf-loop: In your profile it says that your home country is China. But in the footer of your postings it says that you are reseller in Finland. Can you provide more details?...
I have two home. One in China and one in Finland. At this time I'm home in China. My main home country is Finland and I'm Finnish people. My family is Finnnish/Chinese.
Soon I'm in Finland (and there I'm normally mostly)
My profile show current situation. Forum can not show double country and flag.
... How come you have all these detailed tables from Owon?
I have made these. (data in tables are from my own tests, not from manufacturer or some other sources)
« Last Edit: December 07, 2015, 04:08:26 pm by rf-loop »
Offline rf-design
« Reply #16 on: December 08, 2015, 08:04:54 am »
I am interessted in your experience with the HMCAD1520. The datasheet actual shows only typ values for the spurious. Are you one of the pilot customer of ADI as these adcs with quad/dual/single modes are specific for scope markets? Do you got more informations than a sample, datasheet and evalboard?
Does ADI have plans to bring up an AFE which is on par with a 12bit class ADC? To me it seems using a high resolution ADC with a 3% DC accuracy AFE little ugly. Also presenting 12bit w/o mention important specs as gain drift, offset drift, droop, overdrive recovery and so on is unfair for the uneducated user. So he wount know that the 12bit promise could not be delivered.
Do you build the AFE discrete? Or is it a mixture of OpAmps and discretes?
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #17 on: December 08, 2015, 12:42:44 pm »
My guess is that rf-loop simply has access to one of these OWON 12bit scopes, not because he's developing a product with that ADC or because he has some eval boards.
Offline coppice
« Reply #18 on: December 08, 2015, 02:16:14 pm »
Basically all DSOs use flash ADCs.
Name one DSO made in the last 20 years that uses a flash ADC?
Offline tszaboo
« Reply #19 on: December 08, 2015, 03:12:18 pm »
maybe I'm ignorant, but what is the point in 12 bits? you would need a screen that resolution to have meaningful representation, and voltige measurements on a scope are affected by the poor DC parameter opamps in the signal chain.
Do you want 12 bits for FFT, or is there any practical reason?
Offline coppice
« Reply #20 on: December 08, 2015, 03:17:51 pm »
Having high res data for post processing, like FFT processing, would be the main practical use. As you said, it doesn't add a lot to a waveform viewed on the screen.
Offline C
« Reply #21 on: December 08, 2015, 05:22:24 pm »
Think of the one 12 bit data stream as being more scope channels.
Channel one the full signal.
You could then have more channels showing an expanded view of the signal.
Channel two could show the expanded view of the positive peaks of signal.
Channel three could show the expanded view of the negative peaks of signal.
Channel four could show the expanded view of the zero cross of signal.
Offline tszaboo
« Reply #22 on: December 08, 2015, 05:43:33 pm »
Oh actually it can be viewed like the Megazoom on Agilent scopes.
That makes more samples, so if you zoom in on the x axis, there is still data.
With this 12 bit, if you zoom in on the Y axis, there is still some extra resolution.
Makes sense!
Offline Neganur
« Reply #23 on: December 08, 2015, 06:02:16 pm »
Uh, all R&S scopes (and Hameg) unless I'm mistaken.
Offline coppice
« Reply #24 on: December 09, 2015, 01:04:08 am »
I can find material on the web which says R&S use converters of their own designs, and I found some performance information about them. I couldn't find any info on the type of converter, though. Do you have any? Its quite possible some people still use flash converters, but its not the mainstream technique these days. Its not the technique the TI, ADI and Hittite (yes I know that is also ADI now) converters in most low end scopes use.
People in forums keep saying that scopes use flash ADCs, but its mostly because they have never bothered to look and see what is really in a scope. Its hard to make a flash converter run fast. It takes too much power, and the die is too big. Unless you need the extremely low latency a flash converter offers it just makes no sense. Pipelined converters run faster, are more accurate, and take far less power.
« Last Edit: December 09, 2015, 01:17:13 am by coppice »
Offline coppice
« Reply #25 on: December 09, 2015, 02:33:52 am »
Moder scopes use pipeline ADC, which is essentially cascaded flash ADC+DAC pairs.
There are various pipelined configurations. Some take one bit at a time, and look a lot like an SAR converter where the stages are spatial rather than temporal. Its quite common to be like the first pipelined converter I used in the late 1970s, where each stage deals with 2 bits. These are often drawn in data sheets like they are a 2 bit ADC, a 2 bit DAC and an analogue subtracter at each stage. However, the ones I've seen the detailed internals of actually use a single analogue block that outputs 2 digital bits and passes on the analogue residual without any clearly distinguishable DAC.
Don't trust the block diagrams in modern data sheets too much. They conceptualise a lot of what is going on to illuminate functionality, rather than implementation details. For example, most ADCs showing a PGA at the input don't actually have an amp there at all. Its all done my smoke and mirrors... or sometimes by switching capacitors or current feed resistors.
Offline Neganur
« Reply #26 on: December 09, 2015, 12:13:25 pm »
Sure:
HMO722/HMO724 http://cdn1.shop.rohde-schwarz.com/media/catalog/product/H/A/HAMEG_DB_EN_HMO722_724_1.pdf
HMO1522/HMO1524 http://cdn1.shop.rohde-schwarz.com/media/catalog/product/H/A/HAMEG_DB_EN_HMO1522_1524_1.pdf
HMO2022/HMO2024 http://cdn1.shop.rohde-schwarz.com/media/catalog/product/H/A/HAMEG_HMO2022_2024_5.pdf
HMO3000-series http://cdn1.shop.rohde-schwarz.com/media/catalog/product/H/A/HAMEG_HMO3000_EN_1_1.pdf
All of those Hameg's have a low-noise flash ADC.
RTM, RTE and RTO only mention "single core ADC". Whatever that is :)
HMO1002/HMO1212/HMO1222/HMO 1232 don't mention the ADC type.
« Last Edit: December 09, 2015, 12:15:07 pm by Neganur »
  • Country: no
« Reply #27 on: December 09, 2015, 04:02:55 pm »
The Owon looks really nice on the video, however I have just a remark.
The horizontal buttons under the screen, really seem a bit low positioned, almost down to the bottom ground level of the scope.
Why didn't they place them in the middle between the bottom of the screen and the bottom of the scope? This really seems a design issue that needs to be flagged to Owon!
« Last Edit: December 09, 2015, 05:23:22 pm by pascal_sweden »
  • Country: no
« Reply #28 on: December 23, 2015, 12:54:55 am »
When will Dave do a review about the Owon XDS3202A?
The specifications for this scope are quite impressive: 200MHz , 2GS/s, 12 bits ADC, 40M, 75,000 wfms/s
First a review about the performance. After a tear down.
But not only a tear down, as I really want to know how this scope performs :)
« Last Edit: December 23, 2015, 12:56:41 am by pascal_sweden »
Offline Muxr
« Reply #29 on: December 23, 2015, 04:20:12 am »
Interesting scope if the 12bit mode can be paired with a usable FFT. Could be quite handy for audio work.
Offline Mark_O
« Reply #30 on: December 24, 2015, 09:21:10 pm »
The horizontal buttons under the screen, really seem a bit low positioned...  This really seems a design issue that needs to be flagged to Owon!
Golly, you're right!  You should contact them immediately!
a)  I guess they never noticed where they had placed the buttons.  This will come as quite a shock to them.
b)  I'm sure they will stop production, redesign the scope immediately, and re-release it properly.
 ;D
Offline Lukas
    • carrotIndustries.net
« Reply #31 on: December 25, 2015, 09:59:43 pm »
It's not interleaved, so no interleaving distortion. R&S rolled their own ADC: http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=6226133 It's a folding/interpolation architecture.
  • Country: no
« Reply #32 on: April 15, 2016, 09:12:36 pm »
When are the others (Rigol, Siglent) following Owon's example? :)
