In short, there's no "best".
The problem is that, as always, you only know one side of the coin.
I, for example, know both sides because I bought and tested both scopes.
This is a more significant difference than just watching videos and reading forum posts.
And from this point of view, I can say that there is indeed a better device, and that is the SDS800X HD.
The DHO800 has an undisputedly better user interface and the HDMI output as an advantage.
But that wouldn't be enough for me as a reason to buy it, because those are nice extras and don't get to the heart of the matter.
As I said, if you don't have any major demands on a scope and if the Rigol is permanently significantly cheaper, then you should buy that.
Otherwise, the SDS800X HD is clearly the better choice.
Buy or borrow one and you will quickly see why I think so.
And in general:
I criticize Rigol, but I would never just talk badly about them as a matter of principle.
I owe Rigol far too much for that.
Back in the day with the DS1000Z, Rigol had given me the opportunity to buy a cheap but good 4-channel scope privately.
In 2018, the next step came for me, again through Rigol, with their MSO5000.
100Mpts, 8 GSa/s, 2-channel AWG integrated, almost 10” screen and all for well under €1500, sensational.
But other manufacturers have pulled the same - and have pulled away because Rigol did not do anything in various areas.
