The Siglent is a superior scope
Not true for everybody.
Why does it matter to you so much?
Because of people making statements like that one.
Rigol DHO800/900 are having adequate sample rate only when 1 or 2 channels are used. All other combinations will make scope show plainly wrong data.
And this one.
It is a superior scope. That is objective fact. It is a better instrument. To measure stuff, you know.
Also second statement about sampling is also completely true.
Looking at many posts here it seems to me that few people use Rigols for real work.
Can you use Performa01 SDS800xHD review and follow it and report same for DHO800?
With same measurements so we can compare? Something like that demonstrating it is better or equal would change my mind.
Facts. Repeating lies does not make it true.
Ignore facts at your own peril.. Gravity does not go away, no matter how many times you repeat "I can fly..."
Like I sad, and I agree with Shapirus, fact that SDS800 is better instrument does not make DHO800 useless of garbage.
In a same way as the SDS1104X-E did not make DS1000Z useless or garbage. But objectively, SDS1000X-E was a better, slightly more expensive instrument. Buying DS1000Z was not a mistake, but SDS1000X-E was better. Both were much better choice that many more expensive scopes from A brands in that segment. And infinitely better than many "weird brand" scopes that were just slightly less expensive.
And to repeat, I personally owned DS1000Z, and apart from FFT not being very good, liked the little thing. It was a good scope for the money at the time. For a period of time I kept it together with Keysight and Picos. Then I bought Miscsig (for portability) and really didn't need it anymore.
Situation right now, to me looks similar. SDS800xHD is better instrument. That does not mean DHO800 is useless.
I cannot comment how annoying and buggy FW on DHO800 is, because I don't use it in real life. I do see Rigol is not doing much there. I don't like that much. DS1000Z had it's problems in beginning, but was generally good in that regard.
I do think DHO900 is a scam though...
