Author Topic: Tek discontinued the K2002 in June  (Read 440 times)
Kean, TylerPeppy, georgd and 22 Guests are viewing this topic.
Offline CyclotronTopic starter
  • *POOF*
« on: Yesterday at 12:45:51 pm »
I hadn't seen it posted and its a significant passing.
https://www.tek.com/en/products/keithley/digital-multimeter/2002-series-8-5-digit-multimeter
Looks like they are promoting the DMM7510 in its stead. No direct replacement offered.
Online KungFuJosh
  • TEAS is real.
Re: Tek discontinued the K2002 in June
« Reply #1 on: Yesterday at 04:12:40 pm »
In a recent conversation with Tek, one of their reps told me:
Unfortunately, I do not believe there are any current plans to create a modern replacement for the 2002. If it is coming, it is far enough out that they are not telling anyone.
Best Continuity Tester Ever
Offline bdunham7
« Reply #2 on: Yesterday at 06:39:56 pm »
Well, it is a 30+ year old design and there aren't all that many use cases where it has any advantage over other models.  I suspect Fortive looked at the relatively low volume on precision bench meters plus the cost of reengineering new models and decided that the DMM6500 and DMM7510 pretty much covered most use cases and the Fluke and older Keithley models were redundant.  I can't say I disagree with them for most cases.  I think they discontinue them when they actually run out of parts and there's probably something in the 2002 that turned into unobtanium.  In the case of the Fluke 8846A I'm pretty sure it was the original Altera Cyclones that Fluke ran out of a few years ago.  They must have made an impressive last time buy because they made and sold the meter for more than 5 years after the last shipment of Cyclones.
Online KungFuJosh
  • TEAS is real.
« Reply #3 on: Yesterday at 06:45:45 pm »
Maybe, but I think there is a market for 8.5 digit meters, and it's big money. The HPAK 3458A is old AF but still widely sold, and Fluke has the 8558A and 8588A models with newer designs and huge price tags. Time will tell whether or not Keithley cares about that.
I think the biggest problem with the K2002 is exactly what you said; an old design with old parts becomes problematic.
Offline bdunham7
« Reply #4 on: Yesterday at 07:24:02 pm »
It's not Keithley, it is Fortive. They have 8.5 digit meters available from Fluke.  They're not going to spend a lot of money designing an all-new high-cost, low-volume product to compete with themselves.
Offline Hydron
« Reply #5 on: Yesterday at 07:38:11 pm »
I was going to say that Keithley IS Fluke (via Fortive), but apparently the bit of Danaher/Fortive that Tek is in got spun off?
Makes a bit less sense given that change, maybe there are commercial agreements as part of that spin off that discourage it? I do think it's a bit of a shame they aren't looking at a 8.5 digit evolution of the DMM7510.
Offline tooki
« Reply #6 on: Yesterday at 07:38:52 pm »
FYI, it is not Fortive: Some of Fortive’s precision companies were spun off as Ralliant, and Tektronix is among them: https://ralliant.com/our-work#our-brands_id
So Fluke and Tek are no longer under one roof, they’re competitors now.
Offline tooki
« Reply #7 on: Yesterday at 07:39:36 pm »
I was going to say that Keithley IS Fluke, but apparently the bit of Danaher that Tek is in got spun off?
Danaher (containing Tek and Fluke) spun off Fortive (also containing Tek and Fluke) which spun off Ralliant (containing Tek).
Offline Hydron
« Reply #8 on: Yesterday at 07:43:58 pm »
Yeah I was being a bit lazy with Danaher = Fortive, was in the middle of editing to correct that when you replied!
Offline tooki
« Reply #9 on: Yesterday at 07:46:44 pm »
Well that’s the thing: I suspect it’s very much not big money. Given that digital electronics have taken over so many things that used to be done with analog electronics, I would imagine that the need for ultra-precision multimeters is smaller than it once was.
So indeed, chances are the 2002 design reached its limits in terms of manufacturability, and that the new owners concluded that the market simply isn’t big enough to warrant the cost of developing a new one.
And let’s not forget that CERN developed its own open-source 8.5 digit meter, probably precisely to avoid having to buy hundreds of $$$$ 8.5 digit meters from Keithley, Keysight, or Fluke. (They wouldn’t have spent all the money to develop it if they only needed one or two units.) But that design is now out there for anyone who wants it, and it’s precisely the high-volume customers who might make more of those instead of buying COTS.
Online KungFuJosh
  • TEAS is real.
« Reply #10 on: Yesterday at 08:36:35 pm »
All you need to do is look at the price points of what's available, and there's clearly market segments not being served. We can speculate all we want, and time will tell if they care or not. In the meantime, speculate away. ;)
Offline bdunham7
« Reply #11 on: Yesterday at 09:45:18 pm »
Hmmm.  It's hard to keep up!  Next we'll see Fluke instruments with subscriptions!
Offline nctnico
« Reply #12 on: Yesterday at 10:38:51 pm »
I don't think you can just go around and built an 8.5 digit DMM as a diy project. Not even in a commercial setting. It takes knowledge and pedigree to hit 8.5 digit accuracy and stability levels. The latter alone takes many years to master. It is like forging Samurai swords. Sure you can make a pointy. sharp object from steel but creating a blade for a real sword is a whole different ball game.
My guess is that Keysight en Fluke will continue with their 8.5 digit meters; historically and pedigree wise, these companies are in better positions compared to Tektronix.
