Author Topic: Cleaning face panel of tektronics scope??  (Read 936 times)
Offline ArioTopic starter
« on: June 23, 2023, 01:44:58 pm »
Hi there,
I received a tectonics 2230 oscilloscope as a present from one of my senior co-workers. It is 100% operational after replaceing a blown rifa suppression capacitor.  I also cleaned the inside properly, since the scope has not really been used since like 1993.
I would like to also clean the plastic face a bit, but I am not sure which chemicals I would be able to use without damaging the plastic or its prints?
Any suggestions would be appreciated. I did try some isopropanol alcohol on a small patch, but it does not work very good to actually clean the plastic.
Regards
Offline David Hess
  • DavidH
Re: Cleaning face panel of tektronics scope??
« Reply #1 on: June 23, 2023, 05:08:15 pm »
Water with a little bit of dish soap is a good place to start.  If something more aggressive is required, then a plastic safe solvent like naphtha (lighter fluid) is good.
Be careful cleaning the knob skirts where they are marked.  The markings are delicate.
The following users thanked this post: Ario
« Reply #2 on: June 23, 2023, 05:59:12 pm »
Hi David
Thank you. I will start tommorow, and post the results. Excited
By the way the scope does not have the GPIB/RS232 comms card. Would you know where I could look for one?
The other option is to make a pcb board myself to add RS232 functionality.
Regards!
Offline nctnico
« Reply #3 on: June 23, 2023, 08:34:32 pm »
I'd stay away from (petrol based) solvents. These are very likely to wipe out the lettering and/or damage the plastic surface (been there, done that). What works well is stuff that is sold as 'Simple green' in the US and 'St Marc' in Europe. This is a strong de-greaser but doesn't attack plastics. The typical use of St Marc is to clean surfaces before applying paint. Most of the dirt on test equipment is grease & dirt from fingers.
Offline David Hess
  • DavidH
« Reply #4 on: June 23, 2023, 09:35:18 pm »
The cards show up on Ebay periodically.  I do not remember if it is the 2230 or 2232 or both, but some of the cards also include more memory for waveform storage.
« Reply #5 on: June 26, 2023, 01:05:15 pm »
Hi David,
Thank you I will have a look on eBay.!
« Reply #6 on: June 26, 2023, 01:08:17 pm »
Hi Ntcnico,
I will have a look thanks, I have not yet started. Would have to find a local product thougth, since the south african rand is quite weak at the moment, to import a product is going to cost to much. If I can find the right product I will rathere wait a bit untill I do!
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #7 on: June 26, 2023, 04:00:03 pm »
DON'T USE ANYTHING STRONGER THAN DISH SOAP AND WATER ON THE BLACK LETTERING ON THE TRANSPARENT PART OF THE DIALS!! It's really delicate!  :scared:
It'll clean the numbers right off! Ask me how I know......  |O
For the actual plastics, case parts, knobs, and faceplate etc, I wash with standard dish soap and water with a small soft brush, then once it's dry, I'll go over with isopropyl alcohol to get anything the soap couldn't clean off.
Sometimes I'll stick non-painted/screen-printed plastics and faceplates in the dishwasher when the wife isn't looking. :D
