Author Topic: 7265 Lock In Amplifier  (Read 4332 times)
Online RoGeorge
Re: 7265 Lock In Amplifier
« Reply #25 on: June 26, 2023, 03:35:05 pm »
The Signal Path channel has at a few videos about lock-in amplifiers, including some experiments:
TSP #107 - Tutorial, Teardown & Experiments with Stanford Research SR530 Lock-in Amplifier
https://youtu.be/rzzliN_vTKs
TSP #147 - Teardown, Repair & Experiments with an EG&G Instruments 7265 DSP-Based Lock-In Amplifier
https://youtu.be/kNnc-lDHtrM
TNP #20 - Teardown, Repair & Experiments with Stanford Research Systems SR830 DSP Lock-in Amplifier
https://youtu.be/figDqnsQD88
I don't have a LIA, but for less sensitive measurements, an oscilloscope in averaging mode can be used as a LIA (when a clean sync signal is available):  :)
https://www.eevblog.com/forum/projects/oscilloscope-with-trace-averaging-as-a-lock-in-amplifier-(rigol-ds1054z)/
