Author Topic: Type of input connectors on a Lecroy DDA-5005A scope?  (Read 2363 times)
Offline JwallingTopic starter
  • This is work?
« on: August 15, 2018, 08:26:36 pm »
Does anyone know what type of RF connector this is? The manual was useless... Ideally, I'd like to go from this to a female BNC.
Thanks.
Jay
System error. Strike any user to continue.
Online coromonadalix
Re: Type of input connectors on a Lecroy DDA-5005A scope?
« Reply #1 on: August 15, 2018, 08:41:21 pm »
you have lecroy prolink adapters to convert this input into bnc, sma etc ...
http://cdn.teledynelecroy.com/files/manuals/wm-gs-e_rev_e.pdf
Another document with some photos
https://www.amplifier.cd/Test_Equipment/LeCroy/DDA5005A_XXL/DDA5005A_XXL.html
The following users thanked this post: Jwalling
  • This is work?
« Reply #2 on: August 15, 2018, 10:33:06 pm »
Thanks, I knew about them but I was hoping to find a low cost alternative. Those seem to go for about $250 USD! I just need to know the part # or type of the connector.
Jay
« Reply #3 on: August 16, 2018, 03:05:39 am »
I would guess some TNC connector,  hum i think some Hp sig generator has them ?? not totally sure.
I think the Lecroy adapters may have some passive or active electronics in them, you have an look a like 6 pins idc connector on them ?
Online nctnico
« Reply #4 on: August 16, 2018, 05:59:52 am »
I think it is a standard MCX RF connector.
  • This is work?
« Reply #5 on: August 16, 2018, 01:14:25 pm »
That looks like the one. I just noted that the Tek TDS7154X and up use the same connector.
Thanks!
Jay
Offline ingowien
  • Country: at
« Reply #6 on: September 03, 2018, 09:53:43 pm »
I think these connectors are called BMA (blind mate adapter), OSP/OSM or RPC (Rosenberger Precision Connector), depending on the manufacturer. However there are several different Rosenberger series, I once was told it's RPC-SP and 10S732-K00N5 could work as RPC-SMA Adapter. Though this one is not affordable and not available in single pieces.
The original adapters are Lecroy LPA-SMA, LPA-K (3.5mm) or LPA-BNC.
You should find some compatible BMA/SMA adapters on ebay. However they don't lock in, so you'll need some external mounting plate and screws to hold them in place.
The following users thanked this post: Mechatrommer, Jwalling
  • This is work?
« Reply #7 on: September 04, 2018, 09:22:33 am »
Thanks. I ended up harvesting the connector from a Tek TCA-BNC
Jay
