The mismatch in the input transistors Vbe, multiplied by the gain of the amplifier (x2) will appear as offset on the output voltage.
I will measure the offset voltage on my clone versus the original board.
I have been playing with the amplifier in LTspice. I believe that it can be made to be better than original design.
It is still a work in progress, but I have attached my latest LTspice model. I have removed the protection circuit for now. I will put it back at the end.
This version has a slew rate of 1600V/us.
I have made the input stage symmetrical and changed the output transistors. C2 and C3 are trimmers used to optimize the waveform.
This circuit could be used with other function generators to boost the output voltage.
I have attached the LTspice model.
Regards,
Jay_Diddy_B
