I have found where all the CMU 200 experts are! I am having issues with completing a B41 upfit.
Summary - Physically installed, ran software does not detect module nor give audio options.
I'll try to give all the important details the first go-round so here goes.
I read through all very informative posts I could find on this subject and the CMU200 here. Broad overview of steps of install module, run software, unlock K29 feature with Python script and done...not mine though.
My B41 board is physically installed in A11 a great diagram on the inside cover completed the front BNC hookups with ease. NOTE: I do not have any other coax connections as mentioned on the diagram with the other X###-ports to other option cards if present as was not included with the module I bought.
My unit is a CMU200 1100.008.002 Original Firmware CMU200 was v5.21.
Original Hardware B11, B21v14, B52v14. B54v14, B68 (3.04), and B96 - I installed B41 (1100.5300.02)
I backed up my CMU harddrive following the HDD Upgrade instructions prior to any changes.
[CMU drive when I received it is a sata 160GB drive dated manf 2015]
Was able to complete steps to boot CF card to install all files downloaded (BASEV5.21,CD2KV5.20, EVDOV5.20, GSMSV5.22, IS1MV5.20) as per others used to install B41 and AMPS options. I believe now only IS1MV5.20 is all that's needed I installed all in order from Base up.
Was also able to complete the Python script to unlock software features.
I did unlock K29 before I knew I needed the B41 hardware though.
With having B54v14 signaling unit with AMPS I should have an AMPS option listed also with the addition of b41 ? k29 option just shows "--" for version #
-Tried Upgrade FW after board change option and deleted install option and re-install of each option and BASE separately with finish button and reboot after each.
What am I missing ? Could these missing coax interconnects between modules be the issue?
End goal is the Audio menu option for use of the Audio Gen/Analyzer .
Thanks in advance !
I feel I am always on the cusp of greatness or failure.
