I don't know if this belongs to the "Other Equipment & Products"
But since it's a machine for making prototype boards, is rather a kind of "Test Equipment".
Here is goes:
For a long time i wanted a machine to make pcbs without chemicals,
A Cnc engraver, cutter, driller.
From china to my country arrived like if the airplain crashed.
Im trying to figure out if the parallel port controller box is damaged or it's me
The machine does not have or i have not found a Mach3 configuration file, instruction, just a Shockwave video in chinese, i can barely understand...
The cd came also with a virus!.Spyware. Detected by Avira.
http://www.avira.com/free-antivirusAnyway...
Since all controller boxes & steppped motors can work different, im a bit confused how to configure the Mach3 software for the 4-Axis REDONDA
www.DONGDADK.com CNC Controller Box i have.
I'm thinking to change the controller box to other brand/design because it's all smd, i like through-hole technology.
Anyway...
The Engraving Machine is model: TS-3040C-H80
It came with a Heavy Duty Power Tool TM-31A 500-20Krpm, compatible with Foredom Motor Tool.
But...
It's hard wired to AC = needs a variac to actually have variable speed,
Make shure you order the 110v version, or you will also need a step-up 220v transformer+the variac.
, machines are by default 220v,
Controller Box has a switch inside, no big deal.
But the Motor Tool don't, so...
Variac + Step-Up Transformer or a new Foredom MotorTool.
Don't know if this has ball bearings inside, the Foredom looks kind of tempting.
Also does not have an Emergency turn-off Master switch, so you also need to add those rack mounted outlet strips with a
Big Red self-iluminated Master Switch.
Problem #1.Mach3 does not work in Windows7x64
Problem #2.Controler Box needs a Parallel Port.
Actually that's cool, the actual problem is that modern computers don't have a Parallel port anymore.
And there are many different pci/pcie cards available,
With different chips, and/or drivers.
I bought 4 to test...
3bumen
Encore
Others with unknown brand but interesting chipset.
I though pci is parallel, and pci-e is serial, and i need a parallel port, but pci-e is faster, so...
I bought 1 pcie & 3 pci cards to test.
From experience i know all USB2 cards perform very different,
To solve Problem#1 i thought to install Windows VirtualPC with XP Mode, and activate Intel Virtualization Technology in the Bios,
& So far Problem#1 is solved.
But that makes Problem#2 even harder to solve...
Some chipsets use an Emulation type drivers that do not get recognized by WindowsXP SP3 in "XP Mode".
Problem #3. is that; i don't know if i solved Problem#2 of if it's the controlled box that is damaged.
To solve It, i need to make a test circuit something like this:
http://www.hansotten.com/index.php?page=test-parallel-port
Or this:
http://www.xlentelectronics.nl/LPTTest/LPTTestUtilx64r.htm
If Problem #3 gets unresolved, i need to format a new ssd hd, with XP Sp2.
Or install Linux CNC software in other partition of the hd.
Problem #4. don't know how to configure the controller box to Mach3 software.
To solve Problem#4 i need help from another owner, with the same machine or analize the circuit & datasheets of every IC in the Parallel Input Controller card,& then analize each steper/pwm controler card, which is time consuming without schematics, so i need also to make the schematics.
Moddifications:Videos that got me started in CNC...
