Author Topic: Confirming specs on a Siglent SDS2104 - 28M sample point memory?  (Read 1086 times)
Offline py-bbTopic starter
  • Country: af
Hi there,
Apparently the Siglent SDS2104 (NOT X) has a 28M point sample memory. I've seen some manufacturers be a bit naughty and measure it in bits, each sample is 8 bit and so you should divide by 8. Or it does some weird channel multiplexing thing and divide by 4 for that as well turning a figure where 28M bits is technically true to a much less impressive 875k point.
Can someone confirm what it does please?
Re: Confirming specs on a Siglent SDS2104 - 28M sample point memory?
« Reply #1 on: August 23, 2023, 03:05:00 am »
Only with early firmware versions at release.
V2 firmware restructured memory management to then provide 70 Mpts.
See here:
https://www.eevblog.com/forum/testgear/siglent-sds2000-new-v2-firmware/
  • Country: af
« Reply #2 on: August 23, 2023, 10:14:12 am »
See here:
So it really can store 28 million samples from the oscilloscope channels at full resolution AT LEAST?
Can you pull the listings off via USB or serial (or GPIB)?!
The following users thanked this post: Caliaxy
« Reply #3 on: August 23, 2023, 02:51:10 pm »
See here:
It's a long time since I had mine so IIRC, yes I believe you could save csv files to USB just as we can with later DSO's. At that time webservers were not in Siglent equipment but you could control them remotely with the EasyScope SW via USD or LAN connection to a PC.
They didn't have a GPIB socket although you could use the USB to GPIB adapter:
https://int.siglent.com/article/detail-152.html
From around here member Performa01 shares some fine posts about these DSO's:
https://www.eevblog.com/forum/testgear/siglent-sds2000-new-v2-firmware/msg814790/#msg814790
  • Country: af
« Reply #4 on: August 23, 2023, 09:46:25 pm »
See here:
Thanks, I come from Lecroy stock (which I wont hear a word against!) but I would like a faster update rate and always more acquisition memory. I'd be willing to trade some accuracy (of oscilloscope displays I'd wager a lot that LeCroy stuff lies the least ;) but sometimes I just want the shape!)
I STRONGLY prefer open source stuff, any comment about whether you can control it over LAN? Most 'scopes support SCPI (or something like that) - if you've read one GPIB/RS232 remote manual you've pretty much read them all IME. Are they like that?
« Reply #5 on: August 23, 2023, 10:05:10 pm »
Siglent and LeCroy have worked closely together for a decade of more and many low end LeCroy DSO's are rebranded Siglents.
In lots of ways Siglent has followed LeCroy principles and now is adding functionality of their own.
However SDS2000 is now a 10+yr old design lacking some of the bells and whistles of later models.
This programming guide should have what you need:
https://int.siglent.com/u_file/document/SDS1000%20Series&SDS2000X&SDS2000X-E_ProgrammingGuide_PG01-E02D.pdf
See the Usage guide on P15.
