Author Topic: Rigol DHO800/900 Accessories and Add-Ons  (Read 1194 times)
Offline DrRKroppTopic starter
« on: August 21, 2024, 03:13:30 pm »
Hi Everyone,
New poster here with a shiny hacked DHO804 (unlocked and running as a DHO924 with 250MHz bandwidth and 10M memory depth).
One of the perks of my old hacked DS1054z was the huge ecosystem of available accessories that people developed for 3d printing at places like Thingiverse and Printables.
There are already threads about unboxing and hacking the DHO800/900 series scopes and I figured it would be nice to put together a central thread with links to things the community has designed to expand the scope capabilities, make it easier to use, or just improve quality of life.
Re: Rigol DHO800/900 Accessories and Add-Ons
« Reply #1 on: August 21, 2024, 03:45:27 pm »
Cooling Mods:
User Gadget designed a fan mount to use a larger and quieter fan: Link to Picture. Printable Files
« Last Edit: September 03, 2024, 08:08:57 pm by DrRKropp »
The following users thanked this post: VP 777
« Reply #2 on: August 21, 2024, 04:41:24 pm »
I designed an easy to print stand for the scope with integrated probe storage. Raises the scope and angles The design files and printable models are available on Printables.
Probe holder includes detents to prevent the probes from falling out when moving the scope.
« Last Edit: August 21, 2024, 04:45:31 pm by DrRKropp »
Offline Gadjet
    • My Blog
« Reply #3 on: August 26, 2024, 08:25:07 pm »
I made a post in another thread about adding a larger silent fan on the rear to replace the internal fan.
https://www.eevblog.com/forum/testgear/rigol-dho-914-(all-dho800900-series)-fan-mod/
The following users thanked this post: DrRKropp, VP 777
« Reply #4 on: August 27, 2024, 07:23:31 pm »
Thanks Gadget!
This looks like a nice mod. The fan in mine doesn't bother me to too bad, but it seems to be a common complaint. I would probably make the mod if I didn't need to modify the enclosure any.
Do you have any links to STL or 3MF files I can add?
Keep the designs coming!
Offline Gadjet
    • My Blog
« Reply #5 on: August 30, 2024, 06:47:13 am »
I will post links to printables when it's finally finished.
I've completed the mount and added a standard wire finger guard and now I just need to break the warranty seal and run the wire inside to the power connector.
There are no modifications to the case required as the fan cable passes through a hole that's already there and the mount screws into the VESA mount holes.
Offline Gadjet
    • My Blog
« Reply #6 on: August 30, 2024, 05:16:22 pm »
Ok so there's another project I've been working on and that's a custom USB port for the DHO 800/900 series of scopes.
Here's some pictures if the first prototype with two ports, I'm working on a three port version as well.
It uses a 3D printed case and allows the wifi dongle and a memory stick or mouse or keyboard to be connected at the same time.
It looks a bit wonky due to me not soldering straight.
Offline Gadjet
    • My Blog
« Reply #7 on: August 31, 2024, 02:37:14 pm »
Offline Gadjet
    • My Blog
« Reply #8 on: September 24, 2024, 10:57:56 pm »
Ok, the electronics came for the USB Hub for the oscilloscope,  this one allows for the use of the logic analyser option at the same time.
All the files are available from printables
https://www.printables.com/model/1016715-3-port-usb-hub-for-rigol-dho800900-series-oscillos
Offline mrisco
  • Country: pe
    • Github repo
« Reply #9 on: September 27, 2024, 01:30:04 am »
I think that this could help to care the USB-C port of our equipment: https://es.aliexpress.com/item/1005006903614114.html
I did purchase three to use with several devices.
2383827-0
DHO800-900 Extended UI: https://youtu.be/mT4ivaMY7zg
The following users thanked this post: Fungus
Online Fungus
« Reply #10 on: September 27, 2024, 05:17:57 am »
I have a right angle adaptor on mine but that looks even better.
Offline Gadjet
    • My Blog
« Reply #11 on: September 27, 2024, 07:49:03 am »
(Attachment Link)
That looks like a good idea as long as it's a good strong magnet and doesn't fall off when you move the scope.
