Author Topic: Considering a new Rigol DHO924 vs. Siglent SDS120X-E model - Any Bug stoppers?  (Read 15113 times)
Offline radiohomebrewer2000Topic starter
Hello,
There seems to be 2 topics related to the Rigol DHO800/DHO900 series scopes.
One topic only allowS discussion of the bugs in the Rigol DHO800/DHO900 series scopes. The other seems about unboxing, teardown, and hacking. Neither topic seems suited to my question.
I heard there are bugs in the Rigol DH0924.  Technically, any new model from any electronics manufacturer will have bugs...  So, not a shocker.
Have the bugs been fixed?  Are they important? blockers?
I am no professional; I am just an amateur radio operator who likes to build and test radio equipment in the HF frequencies and below including audio frequencies.  So, are the bugs a blocker for an amateur who would only be doing common measurements, such as, measuring the frequency and voltage of a VFO?
I really like the FFT math function in the new scope.  Which is why i was also interested in the Siglent SDS-1204X-E.
But maybe I can get by with just a TinySA as a spectrum analyzer.  Sure, you can get a Siglnet SDS-1104X-E and hack it, but then you still need 4 count of 200 MHz probes. Pay that, you might as well have bought the SDS-1204X-E.  I really like the markers and table listing the peaks in FFT - very helpful for identifying the harmonics and if there are indeed down below enough to meet government regulations concerning transmitter emissions.
The new Siglent SDS800X HD series scopes look nice but past my budget of $700.  Besides, they just came out.  I would rather the professionals/experts find the bugs first.  As an amateur it is hard enough to know if I properly measured something vs. the device under test really does have such and such issue vs. some unknown bug.
Yet, the Rigol DHO924 is a very nice looking scope with a lot of cool new features including a very nice FFT that gives Siglent a run for the money.
So hard to chose between the two scopes which are around the same price right now in the USA.
Thanks in advance,
Daniel
Over some years I have really liked SDS1*04X-E however SDS800X HD is a big step forward and a next level product.
I can see my SN# 0012 SDS1104X-E gathering dust and SDS814X HD becoming my goto DSO despite access to much higher BW models.
Even the cheapest 70 MHz SDS804X HD seriously challenges the SDS1104X-E 100 MHz BW.  :o
You need compare the datasheets with more care.
Online egonotto
Hello,
I would consider a Siglent SDS804X HD and a version of the NanoVNA.
Best regards
egonotto
Offline thm_w
  • Non-expert
Please read the existing threads and discussions if you can, there are many. There is really not much reason to buy a DHO900, its poor value. The choice would between DHO800 and SDS120X or the SDS800 HD model. Or some similar combination.
The DHO800 base and SDS800HD 4 channel base are both priced the same, $440.
https://www.eevblog.com/forum/testgear/rigol-dho914s-vs-siglent-sds1104x-e-hands-on-(i-have-both)/
OK.  I have been convinced to stick with Siglent.
To me 4 channel and 200 MHz are not something I have to have.  They are something nice.
So, I could get away with a 2-channel 100 MHz model.
Even though i am interested in HF frequencies and below (30 MHz and below), I probably will not be doing anything above 15 meters (21 MHz) anyways.  So, 100 MHz is good enough.  I am unsure about 2 or 4 channels though.
However, there is 2 features in the SDS1104X-E and SDS-1204X-E (4 channel scopes only) that are not on the SDS-1202X-E which is a 2-channel scope.
For FFT math, there is the very cool feature of peak markers and a table that lists those peaks.  I went "wow" when I saw those features.
So, I have a question about the SDS800X HD series - in particular a model like SDS812X-E or SDS814X-E - can they do the peak markers and the table like the SDS1104X-E and SDS1204X-E can.  If not, I am not interested in the SDS800X HD series then.
For the SDS800X HD, I think I have seen the peak markers in screenshots or videos (I could be wrong), but I have not seen the table of peaks.  Does someone have a screenshot of this?
I do know the price for the Siglent SDS-1204X-E when including the EEVblog coupon code at a place like Saelig in the US, the price is very nice...
I have a TinySA and NanoVNA, but the screens are small. Plus, I have to get them out of their box when I use them. The scope would just stay on the desk to use immediately.
Thanks ,
Daniel
You can find all you need to know in this post and excellent thread.
https://www.eevblog.com/forum/testgear/sds800x-hd-review-demonstration-thread/msg5293765/#msg5293765
While the FFT screenshots are only showing a couple of markers, IIRC you can have 10.
Offline shapirus
  • Country: ua
Just get 4, unless you have a *very* good reason not to. If you have them, you will need them sooner than you might think.
The following users thanked this post: thm_w, KungFuJosh, Martin72
Online skander36
I don't see the reason to oscilate between DHO9xx and SDS120X-E. Siglent SDS120X-E is an old model (I had 1202X-E), poor construction and old, slow software.
What remain is DHO 9xx vs Siglent SDS800X-HD. But here again there is not much to choose. While Rigol is better in terms of hardware solution and inovation as well as design and physical contruction, Siglent is also better than Rigol in terms of software application, much better I can say. For me is a no brainer choose - Siglent SDS804X-HD is about 486E and can be "upgraded" to some extent.
(I have both SDS1000x-HD and DHO 1000, and in the past SDS1202X-E).
« Last Edit: March 08, 2024, 08:49:28 pm by skander36 »
Offline baldurn
Are you aware that the Siglent has a public key generator, so you can upgrade from sds804x hd to sds824x hd at no cost? Just beware that you only get 70 MHz probes with sds804x hd. It is still much cheaper to buy sds804x hd plus better probes.
The price difference between 2 and 4 port model is just 50 euro. Why not get the 4 port model but maybe only 2 upgraded probes (if you need them)?
804x hd is €409 plus 2x PP215 200 MHz probes at €30 = €469
The following users thanked this post: radiohomebrewer2000
Video showing what I mean.  The link to the video starts in the middle of the video to show what I am talking about.   Siglent may not be advertising this even though it is included (or maybe not) because it is not a "new" feature.
https://youtu.be/2F-qECVs5L0?t=244
See the FFT Math - Marker type of Peak - Table - sort by amplitude
Online KungFuJosh
  • TEAS is real.
Rob responded- he said you can have up to 10 peak markers, and Performa01's thread shows a ton of examples, including the FFT peak markers you asked about.
BTW- don't buy Siglent probes. Check out probemaster.com for nicer probes if you need them.
Online Fungus
Hello,
I wouldn't buy a DHO900, I would buy a DHO800.
You can get the cheapest model and "upgrade" it to any other in a few minutes over Ethernet.
The only thing I know that simply doesn't work is video triggering.
Apart from that everything else is minor annoyances. Some settings aren't remembered when you power off, serial decode needs you to set probe ratio to 1x for the threshold level to be displayed correctly. Half a dozen things on that level.
Apart from that it's awesome. I'll take those niggles over any old fashioned 'scope under $1000.
The future is here and I'm not going back.
« Last Edit: March 08, 2024, 06:24:46 am by Fungus »
Online ebastler
I wouldn't buy a DHO900, I would buy a DHO800. [...]
Since we have established that FFT is of specific interest to the OP, I think that alone tips the scales in favor of a Siglent scope in this case. The lack of FFT averaging and peak detect modes, sometimes inconsistent parameter settings, and dubious window functions are major drawbacks in Rigol's FFT implementation.
I highly recommend the new SDS804X HD, with the possibility to do a "free upgrade" to the 200 MHz SDS824X HD version. In that respect I agree with Fungus: "The future is here", including 12-bit and touch interface capability, so I would no longer buy the SDS1...X-E series.
Don't be deterred by the fact that the 800X HD series is new. The software is essentially the same as on the well-established higher end models, and actually is more mature than Rigol's DHO800/900 series. (Or Rigol's 1.5-year-old DHO1000 series, for that matter.) In fact, I have only seen one issue, in a rather exotic operating situation, described on the forum so far.
« Last Edit: March 08, 2024, 07:20:20 am by ebastler »
The following users thanked this post: Performa01
Sorry, been busy......
Zero signal but attached screenshot should give some idea of Marker capability and the FFT Tools menu.
The following users thanked this post: rogerggbr, radiohomebrewer2000
Thanks.  I am sold on a Siglent SDS800X-HD!
Great information and screenshots coming from Performa01, Tautech, and others.
Now, I am just thinking of the model.  I do not need the top model because I can "upgrade" later to a higher bandwidth but that would require buying scope probes that can handle that higher bandwidth.  Plus US$799 is too much for me to spend.
And finding an authorized Siglent seller in the USA that has the scopes in stock...  These scopes sell out fast when they get a few in stock I have noticed...
So, I have been eyeing Saelig but their site does not indicate in stock or not.  I may have to call them to find out.
Tequipment does indicate whether they are in stock or not.  But, with Saelig, I have their discount code from EEVBlog.
Amazon has a really good limited time deal for US$579 for their Siglent SDS1204X-E.  And if SDS800X HD series model had not come out, I would have already pounced on that!  No joke.
Some hams are telling me - I do not really need 4 channels, but get as much bandwidth as you can.  However, the 2-channel SDS800X HD scopes do not include a Ext trigger input.  Why did Siglent omit this?  So, I may need to go with 4-channel after all.
I think 70 MHz should be good enough for ham bands like 80, 40, 30 - and just maybe 20m as well?  This would be 3.5 MHz, 7 MHz, 10 MHz, 14 MHz.   Sure, there are other HF bands (Shortwave) that would be interesting to build like a 15 meter (21 MHz) but these bands depend on good sun spots to be open.  Granted 2024 and 2025 are good years for sun spots.  I heard that the bandwidth of the scope should be 4 or 5 times the frequency you will measure. And then someone else said 10 times.
So, hopefully 70 MHz is good enough.  If not, I can always "upgrade" to 100 MHz or 200 MHz and get the scope probes for that.  And I do not necessarily have to get all 2 or 4 probes for 200 MHz.  Just get what I need for whatever scenario.
So, I am thinking of a SDS804X HD or SDS814X HD.  Well, at least I have seen the SDS814X HD in stock.  The others sell out quickly.
My current oscilloscope is a HP 54600B 100 MHz 2-channel digital oscilloscope.  Made in early 1990s I think.  I scored it off ebay for $55 in 2022.  Surprised it worked!  I have been eyeing the Siglent scopes for awhile though.
However, measuring a VFO signal above 2 MHz was not stable using my HP 54600.  The measurement bounced around - both the frequency and voltage.  I heard the Siglent SDS1000X-E scopes provide a more stable reading.  And I am hoping the SDS800X HD scopes provide even more stability.  So, if there is any big reason why I would get this scope - this is it!
Because the frequency from my HP 54600 scope was bouncing around, I had to switch to my HP 5314A frequency counter to measure a stable frequency.  Do not get me wrong - I am happy with my HP scope - it is my first scope.  And when I needed to see the waveform of my crystal tester I home brewed, it showed the wave form, frequency, and voltage.  The crystal tester was basically a Colpitts oscillator.
Or, I am not doing a measurement properly?  I just do not know.  I am an amateur after all.  But I do want to learn these things because I want to get to the point I can design my own radios.
Thoughts anyone?
Thanks,
- Daniel
Offline iMo
  • Country: va
@Daniel - the 54600 should work fine for watching your RF signals at all HF bands (considering its 100MHz BW). See my shots in the "54600A thread".
Your "VFO above 2MHz bounces around" - that could be easily caused by the construction of your VFO. Here you have to provide more info (ie in the RF, Microwave, Ham Radio section).
Offline baldurn
Those hams are saying that for only three reasons:
1) Their old boat anchor CRE only has two channels, so therefore it is enough.
2) They never touched anything modern electronics, not even a simple Arduino.
3) Their old boat anchor CRE can not do digital anyway.
You want 4 channels because it is needed to do protocol decodes. If you ever have a simple microcontroller project and need to figure out why the SPI communication is failing, you need this.
Even if you only want to do HAM stuff, unless you only want to work on restoring ancient radios, realise that radios all come with microcontrollers and digital internals these days. Especially all the kits that you can build.
I am going to recommend the SDS804XHD and 0, 1 or 2x Siglent PP215 200MHz probes. This combination is cheaper than SDS814XHD and gets you 200 MHz probes instead of 100 MHz probes. You can wait to buy the probes until you need them.
Remember that sometimes you will connect directly to the scope using a coax cable instead of probes and get the full bandwidth that way. Just make sure to have a through 50 ohm terminator for this purpose.
Offline Caliaxy
Be aware that there is an EEV blog discount code for Tequipment, too.
Online mawyatt
We get all our Siglent gear (11 instruments) from Saelig, including the new 814X HD. Their Siglent shipment arrived Friday 3/8 and they shipped out the same day which we received Monday 3/11.
Best,
~Wyatt Labs by Mike~
Baldurn, No.  The ham who mentioned he only needed 2 channels uses a Siglent SDS1202X-E scope as many other hams do.  But this 2-channel scope also has Ext trigger input as well.  The 800 series does not.  I was actually considering a SDS1000X-E series scope until I discovered the SDS800X HD series was being released to the West...  But you are correct about this ham not using microcontrollers.  But later, I will mentor him on them since he has been mentoring me on many homebrewing topics.  Last year, I built a VFO using a Arduino Nano, Si53531A clock synth IC, rotary encoder, and a i2c LCD Display, but I already knew Arduino since it was microcontrollers that got me into electronics in the first place.
Like iMo suggested, I will move my discussion of the ham radio stuff and measuring a VFO with an oscilloscope to the appropriate forums.
Thanks everyone for your replies.  I think I beat this topic to death.
Offline eTobey
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
The good thing about siglent is also, you can download the firmware without a stupid login. I had to do this with the rigol, but their stupid login page was as buggy as their Oscilloscope.  :-DD
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD issues/tips/workarounds
Offline alank2
What is the general consensus about which unit is better built, the DHO800 series or the SDS800X HD series.  I saw the teardown of both of them, and honestly, it seemed to me like the Siglent was better built.  It had a full metal cage, real heat sinks on everything, it just seemed to my eye to be a higher quality build.  Am I wrong?  Do you guys think the DHO800 is better built?
Online KungFuJosh
  • TEAS is real.
There are two positives for the Rigol: HDMI out and VESA mounting. That's it. Those don't matter to me, but some people prefer it.
Look at the demo thread for the Siglent, it's outstanding: https://www.eevblog.com/forum/testgear/sds800x-hd-review-demonstration-thread/
Offline eTobey
That VESA mount is actually stupid: It is very likely that you would block the air flow for the fan.  :palm:
Offline shapirus
  • Country: ua
I own the DHO804, and it's a half-toy really. Lots of dumb engineering decisions, both hardware and software (*especially* the latter). I bought it because: a) it's easily hacked to unlock full bandwidth; b) it's quite compact; c) it's cheap; d) it's readily available on aliexpress, and that's the only place where I can buy *any* scope for a reasonable price without an x2-x3 multiplier; e) I was ready to modify certain things such as add an external 120mm fan. And of course because its primary functions work quite well. But overall it leaves an impression that the only part in it that was designed by professionals who knew what they were doing is the analog frontend.
p.s. I still like it. It's an ugly duckling.
« Last Edit: March 15, 2024, 09:51:41 am by shapirus »
