Author Topic: Any more in-depth info on the YR1035+ battery tester / milliohm meter?  (Read 4374 times)
Online danno_cj
Re: Any more in-depth info on the YR1035+ battery tester / milliohm meter?
« Reply #25 on: October 01, 2024, 04:53:46 pm »
The listing page from the shop that I bought is not valid anymore. The price was 61 dollars but I paid 55 because I had a 6 USD coupon. I bought the version with both probes and battery holder. The last link that you have posted is from official store. The pictures submitted by buyers match with my unit, so from there you get genuine device.
The following users thanked this post: isabido
Offline isabido
« Reply #26 on: October 03, 2024, 07:00:25 am »
I finally made the return and bought an "original" one, I hope! on this page.
https://es.aliexpress.com/item/4000055332778.html
Online DaneLaw
« Reply #27 on: October 03, 2024, 11:58:54 am »
* https://aliexpress.com/item/4000055332778.html
Here you can see a comparison, between
* Yaorea 1035+
* Non branded YR1035+
* Fnirsi HRM10
* RC3565
Its a mixed bag across the field, the RC3565 seems to be able to go down to a decimal more, on its ohm.
*Have removed the regional "es" from your aliexpress link, as it tends to mess up cookies - changes regional settings.
The following users thanked this post: isabido, RAPo
Offline isabido
« Reply #28 on: October 10, 2024, 02:31:00 pm »
Enigma solved! Fantastic seller. EVERYTHING ORIGINAL, nothing to do with the FAKE equipment that I received.
Perfect precision.
You can see the images.
https://imgur.com/gallery/yaoera-original-MAxoJFB
The following users thanked this post: RAPo
Offline al777
« Reply #29 on: October 13, 2024, 05:04:18 pm »
I have a RC3563 and like it quite much.
The biggest issue with these 4-wire-meters is that they do not do a plausibility check of the 4W-connection. A keysight benchtop DMM displays no reading when one of the 4 wires is not connected, but the RC3563 often displays instable or inplausibly low or high values in that case. I don't want to complain due to the fact that you can get around 100 instruments of one type for the other, but it´s good to know that there is a cause for false readings.
Due to the same reason I build some pseudo-4W-test-leads where the L- and U-lines are both soldered to a short and sharp test needle. That way the contact resistance is of course not compensated, but for quick comparison of many parts it´s more reliable - and you can always fall back to the true 4W-leads if doubts arise.
Beside that it´s a really versatile tool. Not only for batteries but e.g. also for in-circuit test of capacitors or as a milliohm-meter for plugs or switches.
I decided to reply to this thread to keep it all in one spot - and to say thanks to Phil1977 for the idea!
I also have the RC3563, love it and it has a permanent spot on my bench. My kit came with battery holder, pogo pin-based probes and the Kelvin clamps. All good, but not ideal for small parts or small test points on a PCB (in some cases I use PCB traces as small value shunts - need to measure those to ensure the fab didn't screw my calculations :) ). I was getting by with the kit, always thinking that shorting the primary and sense lines ahead of the test point will introduce too much of an error and therefore would end up being wasted effort. But Phil1977's measurements made me try it.
First I dug out from the pile all possible options for the tips. And to my surprise, the cheapest tips (free essentially) that came with one of the cheap multimeters were the best. They are from the kit which comes with various 4mm thread screw-in attachments. One of the attachments were just the short 2mm tips with 4mm thread on the other end. Not even sure what was their use - screwing them into the female thread "receptacle" makes an oddly short "multimeter probe" and the included actual multimeter probes do have 4mm thread on one end, but permanently attached 2mm probes on the other end, so these little tips were not even the replacement tips... The beauty was that when measured by the RC3563 (with Kelvin clamps, ~10 mm apart on the same tip), each of these tips gave <0.5 mOhm. I had to wipe them well with 99% IPA to get that though.
Next, I looked around for what will be good to use as pen-style holders for these tips - and sure enough, Bic "Round Stick" pen (the worst writing instrument, but cannot be any cheaper :) ) were perfectly accommodating the 4mm thread side, not as a thread-in, but as a very snug press-fit. With the back of the tips properly wetted with solder - they were ready to go. I chose Red and Grey pens to make them look more like actual probes :).
It worked out very well, with round trip resistance as measured by the RC3563 being just over 2mOhm. Thanks to 4-wire setup - I used light two-core red+black wires, thin, flexible and yet giving great result in the end.
Of course I could not stop there - the odd GX16-4 connector comes as a pair, the plug (what I needed) and the receptacle (would be languishing in the odd parts bin forever). So my next move was to use the receptacle and make an adapter so that I can use the same newly created probes (and the RC3563 kit probes as well) with my bench multimeter, Siglent SDM3065X for 4-wire resistance measurements as well. So, with sacrifice of the 4 banana plugs and with upcycling of a couple of old PCBs cleaned of any parts - the adapter was created!
Have a look at the pictures. The adapter looks a bit "steam-punk" style, but I like to reuse the material that otherwise would be wasted, so let's call it "stylish looking" :). And measurement with SDM3065 shows 6.8mOhm round trip, not bad at all.
I hope this may inspire someone else to enhance their bench setup as well. Special thanks to Phil1977 as well as the community and the person who supports the RC3563 Wiki page!
All the best to everyone!
20241230 update: added a 3D printed enclosure to make it look less "steampunk-y" :-).
« Last Edit: December 30, 2024, 07:28:34 pm by al777 »
Offline Phil1977
« Reply #30 on: October 13, 2024, 06:08:47 pm »
Thanks for the nice feedback and great idea with the 4-wire adaptor for the bench multimeter!
The following users thanked this post: al777
Offline Filippo52
« Reply #31 on: December 01, 2024, 08:32:33 am »
Good morning everyone
Thanks for this thread full of information on the YR1035
I have two yr1035+ one almost certainly original with the yellow writing and the internal component initials erased. The other one is definitely a clone with the internal component writings not erased.
They seem very very similar.
I wanted to try to do a calibration
The original model has the calibration menu but it does not activate by pressing the button nothing happens
In the clone even though the same number 7 exists  inside the menu there is not even the word calibration and only "---" appears.
Does anyone know if there is a way to enter the calibration menu?
I read that in the new versions the menu has been deactivated but since they have to do the calibration in the factory maybe there is a trick to get around the block.
It would be very useful because the instrument has a very high resolution but given the price and the quality of the components used it is quite normal for there to be a drift with time of the component values ​​and a calibration would be very useful.
Thanks in advance
Filippo
Offline LarryR
« Reply #32 on: December 22, 2024, 03:30:08 pm »
Hi Filippo,
Would you be able to post internal photos of your yr1035+ clone that has the part numbers still on the ICs?
My yr1035+stopped measuring voltage but still measures impedance and knowing the IC part numbers would help troubleshooting.
I noticed that my unit uses a daughter board soldered to the main board. It has 2 MOSFETs on it.
Thanks
Larry
