I have just purchased exactly the same model as you have shown pictures of. I know nothing about these and I would greatly appreciate if you could take the time to answer a couple of questions as you seem to know a lot more about this galvanometer then I do.
1. Can I safely connect an ordinary battery (AAA, AA, C,D, 9volt, 3 v lithium, etc. to this device? The reason I ask is from the little bit of information I have gathered is that it seems that if the current is too strong there is something that could burn out. Is there a limit of time I can activate the galvanometer that makes it more liable to burn it out? Could I connect a car battery to it without any danger? Does it always require a resistor between source of current and galvanometer? If I'm correct this is only good for DC current and not AC current?
2. What do the numbers on the dial refer to: volts, amperes, ohms?
Thank you for taking the time to answer these questions, you can answer me directly at sennevillepete@hotmail.com
Pierre
