Sure, i haze a nice new rigol too. You can shift horizontal and crank up time per division until you are out of sample ram for the desired time shift. That is good, but it is zoom. A delayed sweep (or acquisition maybe in modern terms?) lets you capture after a delay many times the length of sample memory at max sample rate. The hardware counts off time during the programmed delay, bit doesnt waste sample memory until it is time.
