Author Topic: Rigol DS2000A Upgrade that worked for me today (Dec 11, 2018)  (Read 783 times)
Offline kenche
« on: December 12, 2018, 02:39:23 am »
If you follow the instructions on the link closely it will create the correct code. Instead of creating a file on a USB drive, I entered the code using the EDIT function on the scope. https://www.bambach.biz/projects/elektro/upgrade-rigol-ds2072a-to-ds2302a/
Offline clytle374
Re: Rigol DS2000A Upgrade that worked for me today (Dec 11, 2018)
« Reply #1 on: December 16, 2018, 08:20:59 pm »
It was the only way I could get it to work also.  Did you get the 300mhz code to work?  I got 200, but not 300.
