Author Topic: Keysight DSO1014A - a new bug?  (Read 1143 times)
Online nfmax
« on: September 19, 2016, 07:11:02 pm »
I have just found a bug with my Keysight DSO1014A, firmware version 011.04.00.04.06 SP05. Under specific circumstances, the tracking cursors stop tracking the selected waveform, where this is MATH/FFT.
To reproduce:
Select Default Setup
Apply a 1Vpp 1kHz sine wave to CH1
Set CH1 to probe X1, 200mV/div
Set timebase to 20ms/div
Turn on FFT, Blackman window, dBV display, 10dB/div
Turn on cursors in tracking mode, set both A & B to FFT
Adjust A to 1.000kHz, B to 2.000kHz
Now use the horizontal controls to set the FFT display to 62.50Hz/div, centre frequency 1.000kHz
The cursor no longer tracks the waveform!
There seem to be other manifestations of this bug. I have seen a cursor apparently tracking the FFT trace's old position after a zoom/pan operation, and I have seen a cursor track only across part of the displayed trace. Sometimes the cursors seem to be unaffected by zoom/pan, but the recipe above seems to provoke it every time.
Anyone else seen this? Are you there, Daniel?
Max
Edit to add: If you look closely, cursor B is just to the left of the right hand edge of the scree, yet its frequency is still shown as 2.000kHz. This is also wrong!
« Last Edit: September 19, 2016, 07:15:16 pm by nfmax »
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
Re: Keysight DSO1014A - a new bug?
« Reply #1 on: September 20, 2016, 04:07:59 am »
Hi! I'll take a look at it.
Online nfmax
« Reply #2 on: November 30, 2016, 02:27:39 pm »
  • ALL THE SCOPES!
« Reply #3 on: December 01, 2016, 12:57:56 am »
Yes, thanks for the thread bump and sorry for not responding sooner!
It does look like a bug, but it only seems to happen at the very most extreme setting of the FFT. Can you verify?
