Yeah, the lack of stability was what determined me to replace all the bloody optos, their current transfer ratio (CTR) decays over the time and this translates in the changing of digital signals delays, because the input signal slew rate is determined by the driving resistor and they were using "clever" techniques to get some delays between digital signals depending of drive current and the specific characteristic of that individual opto.
So it sounds like it's not just a case of replacing them with newer or faster ones - but matched to the original devices, which have decayed by now and the selection criteria isn't written down anywhere
When I was looking at replacement optos I was wondering if a different device e.g. MCT61/62 with higher CTR would cover the selection criteria - but sounds like it would just screw up timing even more.
I have two of these 1062 units - so if I could rig something to read out the CTR differences on each IC. That might show something about the selection criteria for each slot (or dot colour). Two samples isn't really enough to do it with any confidence but combining 2 units with the white/green/red dots (assuming all white dots mean roughly the same CTR) would maybe give enough info to get a clearer idea.
Of course this means specially selected and paired optos (this why they are marked with those color dots) and when they decay the CTR is even stronger dependent of temperature and the fun starts.
If it were just one or two optos it might be better to use a different device and adjust the resistors to get the right behaviour. But there are lots of optos in there - many dual devices.
Also, hand-selecting the 'right' values these days would probably be difficult - many components don't vary much within a production batch. I was hand-sifting some power transistors recently for a repair and they were all effectively identical.
Basically, if the analogue stuff is correctly set according to the calibration procedure, the ADC is good for 7 1/2 in all the 1061 series as well, the only difference is how it is driven by the digital board and that un-funny unobtanium POS from Ferranto.
Which one is that?
One of my little projects is to decompile the software and fully replace the bloody digital part with a modern MCU board, the forrum post is around. It's a fun thing, but I don't see it getting too much traction, the 1061, 1061A and 1071 are becoming rare and not many people are willing to thinker with this stuff when they can buy an HP something, re-cap it and be done with it.
But I find it fascinating.
I picked these up because I wanted something with good precision, not too expensive (and they weren't!) and with a lit display which I can read from a few feet away in crappy lighting conditions. So that means LEDs or a chunky VFD. No LCD stuff. I think these orange displays look much better and clearer than any of them. I was lucky to get two with low hours - one has some fogging behind the glass in places but is evenly bright. The other looks factory new.
I went for two because I understood the faults could be severe and swaps would improve chances of getting one to work. I think it should be possible to get both working now - getting quite close to it. Unfortunately the issues seem to be similar in both so 'swaps' haven't been as revealing as I was hoping.
Also I enjoy messing with 70s-80s thru-hole tech
Parts which I can actually see & maintain without a microscope and don't lose in the carpet at a 50% success rate. So I don't mind if it takes me a while to bring them back to life.
