Author Topic: Datron 1271 or 1281 displays (Itron DC405E2)  (Read 2182 times)
Offline perdrixTopic starter
« on: July 05, 2017, 05:28:52 pm »
A friend has a 1281 with both VFDs open to air :(.
Does anyone have any spare?  Or have built a replacement using modern VFD or LCDs?
Dave
Offline pelule
  • What is business? It’s other people’s money
Re: Datron 1271 or 1281 displays (Itron DC405E2)
« Reply #1 on: July 11, 2017, 07:13:34 pm »
Hi
I assume you have posted same request at [volt-nuts]
I had same problem some years ago, both 1281 displays have been brocken during shipment.
You may find the posts here in the forum:
https://www.eevblog.com/forum/repair/looking-for-datronwavetek-1271-or-1281-display-unit/msg499126/#msg499126
For the left value/mode display I have not yet found a solution, but I guess a graphic display with fitting length and heigt would be the best.
For the right menu/control display I have found a suitable display, but id would need a voltage converter to 5V and a MCU, which converts the serial graphic information into a graphic display controller format. I have started the sw design, but than I was lucky to get a complete worlking display board for a low budget and so I stopped working on.
You can find the so far result at following site: https://xdevs.com/fix/d1281/
Rear view:
l
Front view:
PS / Added: I did the Itron communication trip already (even with Japan direct). No chance to get NOS parts. Both where custom displays. Best result: I got the data sheet of the DC405E2, which Todd Micaleff posted at his xDevs 1281 repair site.
/PeLuLe
« Last Edit: July 11, 2017, 07:22:12 pm by pelule »
You will learn something new every single day
Offline picburner
« Reply #2 on: February 16, 2021, 08:38:46 am »
I understand it's been a long time but, if you haven't thrown away the instrument yet, now there is a chance to have at least one alternative display.
