Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
DC Electronic Load Korad KEL103 reverse polarity
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DC Electronic Load Korad KEL103 reverse polarity (Read 1079 times)
MrYakimovYA
Regular Contributor
Country:
on:
June 19, 2023, 01:21:10 am »
Hello!
I can't find anything about subj: what will with my Korad KEL103 do if I reverse polarity at binding post? I.e. does KEL103 failed if I connect the + of my source to - of the load and - of my source to the + of the load? User Manual says nothing about it. I have super brand Fujitsu DC Electronic Load at my work. There is a back connected diode at the binding post and reversing polarity does not harm it. So what with the Cnineese instrument?
Logged
GigaJoe
Frequent Contributor
Country:
Re: DC Electronic Load Korad KEL103 reverse polarity
Reply #1 on:
June 19, 2023, 02:26:36 am »
would it be possible to test with some resistor as a safety
Logged
MrYakimovYA
BILLPOD
Country:
Reply #2 on:
June 19, 2023, 01:24:59 pm »
Using the continuity feature of your DMM, see if your negative banana jack, (black one), is connected to your earth ground, (green jack)
Logged
MrYakimovYA
HKJ
Super Contributor
Country:
Reply #3 on:
June 19, 2023, 01:28:07 pm »
Generally DC load to not handle reverse polarity, there will most likely be about a diode drop in reverse voltage (From the diode in a MOSFET transistor).
You can use an external high current bridge rectifier to improve that situation.
Logged
MrYakimovYA
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
