Author Topic: Decent modern Signal/waveform Generator here in early 2024  (Read 13862 times)
Online DaneLawTopic starter
Re: Decent modern Signal/waveform Generator here in early 2024
« Reply #50 on: January 21, 2024, 12:03:24 pm »
I am familiar with the new Rigol DGxxxPro-line and its certain fundamental issues here the last few weeks in use, which makes me wanna look for alternatives
Is there any chance that you might elaborate and share your findings with us?  Perhaps in the existing DG800/900Pro thread if that is more on topic?
Thanks in advance.
Ofcourse NE666   :)
There are two licenses you can add in menu..ch & memory* (*2m to 8m)
It has a temp-regulated fan, that starts up after 3 to 5 minutes and pretty much stays on, even here in the wintertime, - you can get it to stop, by countering the heat with a small fan directed in the back, and the internal fan will cut off, but the fan will more or less constantly be on when in normal use.
When the fan is running, it's annoying as it is both whinny & cycles the fan with minute differences in speed, but could likely be optimized in firmware to an extent but also logical consequence on a unit simply 5½ cm thin, while being quite fast [625MSa/1.25GSa 16bits], but I had hoped it would be more silent after Rigol put so much emphasis on the last signal gen's fan-aspect [DG800 125MSa & DG900 250Msa] by making them passive with Rigols so-called innovative fanless-case design.
Sofar, I don't know if the DG800PRO series hardware-wise is the same as DG900PRO that in model hierarchy peaks at:
[200MHz - 16bits - 1.25GSas - 32M] but I highly doubt that Rigol would roll out the red carpet, so a DG800PRO could be liberated up to those DG922PRO-specifications, when you have in mind what a DG821PRO starts at.
There is a new Firmware on the Chinese Rigol site (date 12-01-2024) it does seem to be the exact same 73MB GEL file for both DG800PRO & DG900PRO. [00.01.00.00.21]
The firmware & software values my unit arrived with [screen picture]
Worth noting these signal gens, do seem to get quite hot, a significant amount of the heat-flow are centered down at the table
Two aspects I really like, are the ability to run it from powerbanks and the 7" screen (1024x600) which makes adjustment & overall user input, way more enjoyable than my old signal gen FY6900.
Even though the screen on paper is merely 1" smaller than my Micsig STO-scope at 8" - it's still significantly smaller from the different aspect ratio of 16:9 vs 4:3 but for a Signal gen, 7" 16:9 touchscreen works well and hopefully this halfbaked mess of a UI where I constantly are meeting various bugs when cycling the menu, will be polished out.
I'm not in a position where I can be to harsh, as I am importing it fresh out of the oven from the Far East and seems to be a very early unit (serial 000013), and using its Western/english UI, while it hasn't been released yet in this region.
These new Rigol DGxxxPRO models have that kinky Rigol-num-dial-circle orientation that has been the norm on their PSUs for like a decade and seem quite hard to love & use (at least at first) I primarily use the touchscreen when adjusting values, works good..
The rotary knob is clickable and feels solid & rigid, not flimsy, and you can cycle the highlighted area around to the different segments, menus, etc. and when wanna go deeper, simply click down in the different menu layers.. works okay.
So far the interaction & input are a joy, but then again anything would likely be - when coming from the FY6900 user interface which are cumbersome to adjust settings on.
The boot-up time takes around 65 seconds, so quite slow, It runs Android 7.1.1
It got around 151 built-in waveforms from scratch, stacked into different categories.
You can sequence the waveforms to your heart's desire amongst the inbuilt  (64 in-line with individual control of loop-values (max 256) & length http://tinyurl.com/mr266mcj
The harmonics allovs up to 20 but also worth noting after watching Batterfly/Saelig's videos on the last gen, there seem to be some features missing' like some of the advanced waveforms, but most of these Batterfly/Saelig videos were done with a RIGOL DG992 signal generator (flagship) Will try to look through the EEVblog-thread on the last gen DG800 & DG900 series to get an idea if some of these features - not least centered around RF perhaps are being implemented with higher revisions, and wont figure on entry units like DG811/812..??
Screen dumps (35) of some of the values & limits on my unit  http://tinyurl.com/3p8w92aw  [IMGUR]
In regards to the fundamentals,  the datasheet & user manual will likely be better guidance, than my crude view.
https://www.batterfly.com/PDF/RIGOL/DG800-Pro/DG800Pro-Series_datasheet_EN.pdf
https://www.batterfly.com/PDF/RIGOL/DG800-Pro/DG800Pro-Series_userguide_EN.pdf
My only comparable, hands-on Signal gen, is an FY6900/60MHz from Banggood GB/EU warehouse clearance sale..In regards to that unit - build quality, etc, it's night & day, which it should be, as the Rigol is more than 5 times more expensive.
The freq-counter allows up to 500Mhz with 7 digit res while DG900PRO opens up to 1GHz both allovs 8 modulation functions.
After 4 to 5 weeks of use, I am liking it more than I did the first weeks, not least after getting a better insight into what you can expect in this price bracket in early 2024, but the fan is annoying.
Will try to see if I can get it across on video, - I also have a temp-regulated fan in my Micsig STO/C-scope which is also quite thin at 5cm, and I have no issues with that fan, none - it gives a somewhat pleasant (for a fan) anonym background swoosh, where the DGxxPRO is a hysteric little whiny fellow, but it does look like it got a weirdly big amount of heat it needs to remove.
Two very important criteria for me' were mobility in lack of a dedicated bench-space & just overall easy interaction when adjusting and rigging waveforms, and both of these its does work well.
All the high current PD-able power banks I tested with work fine with it - 2x QD188-PD, Powercore24, USAMS-CD165, it stays in 15V PD from the start and uses around 35 watt.
The delivered price was a tad under 300 euros.. including both the 25% EUVAT and also the 22Euro VAT handling fee to PostNord.
Entry unit DG821PRO will likely be around that 300euro level when it's for sale in the EU, and 250 to 300US in the states, as the official retail-price in China is 1999CNY [250EURO] while upgrades are 499CNY each
I had hoped other people would be starting to get them about now, but according to both Eleshop & Batronix, it still seems to be some months ahead, and couldn't provide any stock estimates.
I purchased it under the AliExpress BF sale (November 2023), where the seller "Rigol & Fluke" made up a specific DG800PRO listing (after I asked, if he would) so I could take advantage of the Black Friday sale..
He made the listing on the promise I extended the delivery time, as they weren't available in China yet, though only a matter of a few weeks, and planned to be shipped in the first weeks of December 2023 which he more or less honored, as the date on the sig gen's counter FW is 12 dec 2023
A good seller I had talked with previously about new products on the CN market and It looks to be quite an early unit (sn xxxx00000013).
In Nov/Dec 2023 it was still up for debate in China how hackable the DG800PRO series is, but if you can hack a DG821PRO up the DGxxxPRO ladder it could be a price-attractive approach to obtain a potent 16bit signal gen with a good portion of memory.
Accessories incl. were LITEON 65W TypeC PSU, 4mm grounding cable, BNC cable [3D-FB], and USB-A to USB-B PC cable.
« Last Edit: April 26, 2024, 02:00:16 pm by DaneLaw »
The following users thanked this post: Construct, NE666
Offline slavoy
« Reply #51 on: January 24, 2024, 09:51:12 am »
As my first generator, I bought a Siglent SDG1032X and I am very satisfied with it. I use it for various things, nothing with radio. It is probably the cheapest decent generator which works as it looks. Of course, I immediately upgraded to the 1064X after purchase :) Now I would like something over 100MHz, but the prices are high. Maybe I will decide on the 2000X or 6000X series as they remain one of the most affordable and easily upgradeable options I've found so far.
Offline flaotte
« Reply #52 on: February 29, 2024, 02:50:32 pm »
I will interrupt the discussion  8)
looking for really cheap DDS generator. No real requirements. Just got my first scope, may be useful to learn how to use it, etc.
Most of stuff I do is small digital home automation projects.
I am into HAM a little bit, it would be nice if it goes up to 30-60MHz, but no plans for home brewing, except some filters/antennas maybe.
Should I go for FY6900 or is there something cheaper to play around?
Offline Aldo22
« Reply #53 on: February 29, 2024, 03:51:49 pm »
I have an FY3224S for about $50 and that is enough AWG for me for the time being.
You should connect the BNCs to a protective earth (PE) (pull in a 3-wire cable)
I made myself a PC interface because the normal control interface is not so great, but then...
It's a 2-channel AWG with 20/10Vpp, phase adjustment, TTL output etc. Many hobbyists will probably never need more.
https://www.eevblog.com/forum/testgear/feeltech-fy3224s-24mhz-2-channel-dds-aw-function-signal-generator/msg5175198/#msg5175198
I may get tarred and feathered by the test equipment elitists for saying this, but I don't care.  ;)
« Last Edit: February 29, 2024, 04:00:10 pm by Aldo22 »
Offline flaotte
« Reply #54 on: March 07, 2024, 10:34:26 am »
and I have to pay VAT so prices are like that:
FY3224S - 74usd
FY6900(60MHz) - 117usd
JDS6600 (60MHz) - 110usd
would be 50 vs 100 we would have a clear winner. I cannot find any decent options below 70usd, unfortunately.
But not adding 40usd for 2x range may be worth it?
going up to 30MHz is very nice for HAM related stuff, but are they good at high end?
which one from the list would work best out of the box?
Offline Aldo22
« Reply #55 on: March 07, 2024, 10:57:25 am »
FY3224S - 74usd
The taxes...  :palm:
In Switzerland, we don't pay taxes for postal import up to CHF 65.
Therefore the FY3224S is tax / duty free and the FY6900 costs about 22.- extra.
So for me it's approx. 50.- vs. approx. 120.-
The FY6900 is certainly better if you don't mind the extra charge.
« Last Edit: March 07, 2024, 10:59:16 am by Aldo22 »
Offline MegaVolt
  • Country: by
« Reply #56 on: March 07, 2024, 01:03:16 pm »
FY3224S 12 bit.
Other 14 bit.
Offline GigaJoe
« Reply #57 on: April 25, 2024, 02:10:49 am »
FY3224S - I use it for a long time , as some signal source ....  it quite annoying interface where you need to press a single button to switch parameters in a sequence to reach what you need ...  in case - set and forget it acceptable , but when you quite often going to change some output parameters it kind of frustrated ..
so ...   if you need just a signal source ,   to feed something , like trace signal path  that FY32XX acceptable ....  as well you can look at old gens with limit 1-3Mhz local used \ flea market etc. depend on your max MHZ needs...  ;  or if you do TTL for 1-3MHz ...
for a work pattern where you need often change parameters,  jump to there , and there, change this and that .....   unfortunately ,   friendly generators with key pad and dedicated buttons .... only ;   otherwise after some time you will start to kick yourself
Offline Aldo22
« Reply #58 on: April 26, 2024, 08:52:15 am »
...or you can use presets, the Windows software, or write your own Linux software.
The FY3224S is cheap and serves many purposes. Of course it leaves a lot to be desired, but in combination with other cheap devices it can become a useful hobby equipment for little money.
In my case, for example:
FY3224S: 2 channels, 20Vpp, phase, sweep etc.
Hantek DSO2000 built-in AWG: Adds much better rise times, shorter pulses and AM/FM modulation with selectable waveforms (But only 1ch and limited Vpp).
TinySA: Provides much higher bandwidth (350MHz sine, less stepped signal than 12bit) and AM/FM (stepped sine only, 1ch and very limited Vpp).
You can test and learn a lot with these. All of course only hobby/beginner quality. A "decent" signal generator still costs quite a bit of money.
